316
OxygenOS 3.5.5 (MM) OTA for OnePlus 2
  1. yogi.rulzz
    Eclair Dec 23, 2016
    yogi.rulzz , Dec 23, 2016 :
    Network connections disconnect to frequently after update.. I m using rjio and airtel...
  2. Abk2196
    Donut Dec 23, 2016
    Abk2196 , Dec 23, 2016 :
    I can't seem to put my phone into vibration mode after the update. Anyone experiencing the same problem ?
  3. zuzar
    Froyo Dec 23, 2016
  4. Shravan_subbaraman
    Cupcake Dec 23, 2016
    Shravan_subbaraman , Dec 23, 2016 :
    How to use the app lock feature. The lock mentioned at the top is for lock buttons ? so how does the app lock be used ? nd from wre?
  5. Romanicus90
    Romanicus90 , Dec 23, 2016 :
    Holt the power and volume down button for 1 second.
    jahesc likes this.
  6. yogi.rulzz
    Eclair Dec 23, 2016
    Network reset too frequently... Do not download the rom.. I m. Using two sim rjio and airtel.. Let the binary stabilize
  7. aayush.08
    Eclair Dec 23, 2016
    aayush.08 , Dec 23, 2016 :
    Is it just my device or has the update not been rolled out in India? If so, any estimate as to when it'll be available?
  8. Abk2196
    Donut Dec 23, 2016
    Change your VPN to USA. You will get the update
  9. Dalveer
    Ice Cream Sandwich Dec 23, 2016
    Dalveer , Dec 23, 2016 :
    How can I put the phone into vibrate mode? Before I could turn the volume all the way down and now the volume doesn't go all the way down it stays on the lowest volume and the only way to turn off ringer is to put it into silent mode. Am I missing something? And also how do I screenshot now? I used to hold down the power button and the option was there, but not anymore. Any help is appreciated thanks guys!
  10. Deactivated User
    Dec 23, 2016
  11. Abk2196
    Donut Dec 23, 2016
    I have the same problem with the vibration mode.
    As far as the screenshot is concerned, it's under gesture now. You can enable a gesture to run down 3 fingers on your screen to get a screenshot.
    Dalveer likes this.
  12. yogi.rulzz
    Eclair Dec 23, 2016
  13. Abk2196
    Donut Dec 23, 2016
    Still can't get it.
  14. naidu72
    naidu72 , Dec 23, 2016 :
    while doing a voice call earlier version we use to get a full image contact but in this new One it is very small and looks weird
  15. NanaC
    Eclair Dec 23, 2016
    NanaC , Dec 23, 2016 :
    I'm missing the settings option when you long press the home screen.
  16. shivagonal
    shivagonal , Dec 23, 2016 :
    tq
  17. NanaC
    Eclair Dec 23, 2016
    I'm missing the settings option when you long press the home screen after the update.
  18. Deactivated User
    Dec 23, 2016
  19. NanaC
    Eclair Dec 23, 2016
    It's caused me a bug...I no longer have the "settings" option when I long press the home screen. Now I can't hide the shelf or change icon pack.
    satyam.singh likes this.
  20. rkravi85
    Donut Dec 23, 2016
    rkravi85 , Dec 23, 2016 :
    Anybody rooted their phone with current OS 3.5.5?
    Which SU version you have used?
