441
OxygenOS 3.5.6 Hotfix OTA for OnePlus 2
  1. pgomase
    Gingerbread Jan 11, 2017
    pgomase , Jan 11, 2017 :
    Hope u have tried basic stuff like wiping cache, dirty flash, factory reset, clean flash etc
  2. Vcmpo
    Cupcake Jan 11, 2017
    Vcmpo , Jan 11, 2017 :
    yeah I'm already starting using it, but how to root a phone with that vasion?
  3. nikhilanroid7
    nikhilanroid7 , Jan 11, 2017 :
    1st try to clean cache, If it is not work then Flash again with 3.5.5 then 3.5.6 (use full zip).
  4. G_tyler_zettler_ayRr
    G_tyler_zettler_ayRr , Jan 11, 2017 :
    recently updated to 3.5.6 a big issue that I'm having is when I make a phone call and put the phone to my ear the screen turns off like it should but will randomly turn on without me noticing it then my ear starts hitting buttons and can put my phone in airplane mode or hang up it has done this about 10 times since I updated and I've never had this happen before.
    Another problem that I see and do not like is when you put the phone on speaker phone the icon changes ever so slightly you can't really tell what the status of any of those buttons are if it's on or off.
    has anyone else experienced these problems it would be nice to know I'm not the only one.
  5. kaihp
    Jelly Bean Jan 11, 2017
    kaihp , Jan 11, 2017 :
    I'm not seeing this on v3.5.6. Did you remember to clear cache and data when you upgraded?
  6. Dromidas
    Donut Jan 11, 2017
    Dromidas , Jan 11, 2017 :
    Requiring a factory reset of the phone to properly update is even more ridiculous than geforce requiring an account to download nvidia drivers (unrelated except on bs level).
    Do you think they are going to be a professional company and fix this or is the previous update the very last one my op2 is going to ever receive? Cause I'm done with oneplus forever if that's the case.
    Hugh3 and daltocs like this.
  7. bdublz
    Eclair Jan 12, 2017
    bdublz , Jan 12, 2017 :
    Thanks for the info! So far 3.5.5 has been stable, I'll hold off on doing a master reset. If it was nougat I'd be all over that in a sec! :):):)
  8. G_tyler_zettler_ayRr
    Cupcake Jan 12, 2017
    G_tyler_zettler_ayRr , Jan 12, 2017 :
    it was an OTA update is there an option to do that while updating? if not can your point me in the right direction?
  9. flipsyde
    flipsyde , Jan 12, 2017 :
    Thanks for the quick update. But I am experiencing battery drain ever since. Also it takes more than two hours to charge now, how to fix this?
  10. harsh1anand
  11. maddy@one
    maddy@one , Jan 12, 2017 :
  12. ssub16
    ssub16 , Jan 12, 2017 :
    couldn't able to select inbuilt alarm notification tone for alarm.. please fix..
  13. Gorkhey
    Gingerbread Jan 12, 2017
    Gorkhey , Jan 12, 2017 :
    I have been facing the same problem. I didi clean install but it's same. I used GSAM and google service shows the culprit for the drain but have no idea how to fix it.
  14. nikhildamwala
    Donut Jan 12, 2017
  15. Pyae Sone Kyaw
    Pyae Sone Kyaw , Jan 12, 2017 :
    Do twrp recovery work in oos 3.5.6
    Do twrp recovery work on oos 3.5.6
  16. G_Danish_Khan_fwuJ
    G_Danish_Khan_fwuJ , Jan 12, 2017 :
    After updating OnePlus 2 with 3.5.6 version, battery issue is creating a lot issues, 0 to 100% charging time is more than 18 hours. 50 to 100% charging time is 12+ hours.
    On fair and moderate use, battery drainage is too rapid, hardly drained in 2 to 3 hours.
    When switch off the phone and charge, it charged with it's previous speed. But still draining is persisting.
  17. Lakenaattori
    Lakenaattori , Jan 12, 2017 :
    I have quite a problem with my ROOTED 2. I've updated to 3.5.6 and everything is flawless except for the fact that my WiFi won't turn on. Oh and also my gestures are just broken. Halp meee
  18. kaihp
    Jelly Bean Jan 12, 2017
    kaihp , Jan 12, 2017 :
    3.0.2-2 works yes. See post 1 in Spaana's mirror thread.
  19. Vcmpo
    Vcmpo , Jan 12, 2017 :
    it's really good, but how long will u take to Oxygen OS new update??
  20. ram1987
    ram1987 , Jan 12, 2017 :
    @Tony L. we appreciate for the effort you made to fix network issue... please fix the battery drain issue too...And make quick charge if possible... Thanks
