441
OxygenOS 3.5.6 Hotfix OTA for OnePlus 2
  1. Flagada_John52
    Donut Jan 3, 2017
    Flagada_John52 , Jan 3, 2017 :
    Configuration: 100% Stock Encrypted / Locked Bootloader / Stock Recovery / Never Rooted, running 3.5.5
    As I mentioned earlier I was proposed the 17Mb update which failed, then got proposed the 1.2Gb update which failed too multiple times and now only the 1.2Gb update is proposed.
    I read that encrypted users should adb sideload - so this is what I did with both the 17Mb file and the 1.2Gb file.
    None of them work and I have the following message in adb: error: protocol fault (no status)
    I've had adb sideload work previously to load the 3.0 beta - so I'm guessing this is something else.
    => can someone please help?
    Thanks a lot!
  2. Zubairulla
    Donut Jan 3, 2017
  3. F_Naveen_Kumar_UbUy
    Cupcake Jan 3, 2017
  4. emu2604
    Donut Jan 3, 2017
  5. fakhir
    Donut Jan 3, 2017
    fakhir , Jan 3, 2017 :
    My download got stuck at 87%. After several reboot and deleting OnePlus2OTA folder the problem not solved and it remained stuck at 87%. Now I have cancelled the download and started again. The download speed is very pathetic (below 20 kbps) while my internet speed is above 5 mbps. What to do if it again stuck?
  6. chandulal
    Froyo Jan 3, 2017
    chandulal , Jan 3, 2017 :
    network drop is not fixed. still facing it. network is dropping every 1hour
  7. vignesh150
    Cupcake Jan 3, 2017
    vignesh150 , Jan 3, 2017 :
    hello still i didnt get the update wen i ll get. r seriously playing with customers??
  8. Abhishek R Sharma
    Donut Jan 3, 2017
    Abhishek R Sharma , Jan 3, 2017 :
    I didn't get the update (hotfix) not yet... Needed it badly
    Can anyone help with that
  9. Kirubakaran KN
    Cupcake Jan 3, 2017
  10. kumarks102
    Cupcake Jan 3, 2017
  11. Mh_487
    Froyo Jan 3, 2017
    Mh_487 , Jan 3, 2017 :
    Those who are not getting the update, download snap vpn from play store and after it gets installed, open that app and change your country to canada, then check for updates. Hope it helps.
  12. SrivathsanJ
    Cupcake Jan 3, 2017
    SrivathsanJ , Jan 3, 2017 :
    How l
    How long will it take.. It's been a week now... I haven't received it...
  13. Sanketshejwal
    Eclair Jan 3, 2017
  14. The Imp
    Ice Cream Sandwich Jan 3, 2017
    The Imp , Jan 3, 2017 :
    You can downgrade to 3.1.1 by the method given in update thread and then manually flash 3.5.5 and then 3.5.6 over it. This will solve your problem. Some of the files might be missing that's why this is happening. And check MD5 after downloading zip so that you can know that you have downloaded the whole zip
  15. The Imp
    It's incremental so it takes some time and if you are so desperate then use vpn
  16. The Imp
    According to the posts that I have seen it only works with T-Mobile , Jio and a Chinese carrier for now
  17. omprashantjain
    Cupcake Jan 3, 2017
    omprashantjain , Jan 3, 2017 :
    I am having problem while trying to do "Install from local", when I click on it nothing happens. Do you have any idea what I am doing wrong?
    Please help if you know.
  18. lok_jain
    Cupcake Jan 3, 2017
    lok_jain , Jan 3, 2017 :
    Will the forced update cause any problem of region or something else?
    Please tell me because I am not sure.
  19. omprashantjain
    Cupcake Jan 3, 2017
    No it will be fine. Oxygen os has same build everywhere.
  20. G_Sreerangam_Hanumanth_A
    Cupcake Jan 3, 2017
