441
OxygenOS 3.5.6 Hotfix OTA for OnePlus 2
  1. Pankaj_Parasar
    Froyo Jan 3, 2017
    Pankaj_Parasar , Jan 3, 2017 :
    Can you please try *#*#4636#*#* and go into the phone information setting and select GSM/CDMA/LTE auto (PRL) and then report if it helped.
  2. Pankaj_Parasar
    Froyo Jan 3, 2017
    Can you please check and let know if you are on 3.5.5, this is a patch for that.
  3. chirantanad
    Honeycomb Jan 3, 2017
    chirantanad , Jan 3, 2017 :
    @Tony L. @SoniaB Hi, While setting up Fingerprint security...We can register same finger twice... I remember we had this bug in original version... My network does not reset now...But, Airtel India network drops once in a while... I get full network in my moto phone...Please improve network stability and include aggressive doze mode for oneplus 2..
  4. G_Online_Annihilation_bR
    Cupcake Jan 3, 2017
    G_Online_Annihilation_bR , Jan 3, 2017 :
    aftet upgrading to oxygen os 3.5.6 from h2os 2.5.1 i am continuously facing network drop issues on both sim card with different network registered...i even flashed the h20s modem zip then too facing the same problem...please help
  5. viswanathan Muthu
    Donut Jan 3, 2017
    viswanathan Muthu , Jan 3, 2017 :
    battery consumption is because of media server, then deleted unwanted files empty folder, .txt files using any software( SD maid pro, all in one box pro) then switched off the phone, charged till 100% and used my mobile. dis method solved battery drainage problem
  6. Kyllla
    Cupcake Jan 3, 2017
    Kyllla , Jan 3, 2017 :
    @Tony L.
    I still havent even had the update to 3.5.5 (or 3.5.6) and when I check for updates it says system up to date
    Device: oneplus 2
    Oxygenos version: 3.1.0
    If you could please help, I would be very grateful.
  7. Imrsofficial
    Froyo Jan 3, 2017
    Imrsofficial , Jan 3, 2017 :
    you can uninstall it..
  8. Pankaj_Parasar
    Froyo Jan 3, 2017
    Can you please try decryption and then install.
    Settings >> Security & Fingerprint >> (Scroll to the Bottom) Encrypt Phone
    Turn off encryption
    Then go back to settings >> Screen Lock (Top most) >> Set to None
    Now try installing the zip. This is a security feature, not a problem with the zip file. See the attached screenshot for explanation.
  9. Abhinav3718
    Eclair Jan 3, 2017
  10. mindhunter991
    mindhunter991 , Jan 3, 2017 :
    Aaaand Still your thread got merged with this one
    Ha Ha....:D :D
    If you can flash any N rom EASILY, then just flash it.
    But jokes apart, please post your feedback here in the main thread because already there are so many useless threads and we have to keep the forums clean.
    I understand that your intentions were good.
    I'm sorry.
  11. Sandeep_Agnihotri
    Cupcake Jan 3, 2017
  12. Pankaj_Parasar
    Froyo Jan 3, 2017
    Hi Prashant,
    Check the following -
    Are you already on 3.5.5?
    Have you checked the file you downloaded? 17mb?
    If you are on 3.1.0 or less?
    Check the file size? ~1.2GB?
    Have you encrypted your phone?
    Can you decrypt and disable screenlock?
    Let forum folks know if this helps.
  13. aakashsaurav
    Cupcake Jan 3, 2017
    aakashsaurav , Jan 3, 2017 :
    I am still running on 3.5.5 and still facing the network drop problem.
    how to receive this update?
  14. vikas.2728
    Cupcake Jan 3, 2017
    vikas.2728 , Jan 3, 2017 :
    install opera vpn
    select region CANADA
    chek for update you will get it
  15. Pankaj_Parasar
    Froyo Jan 3, 2017
    I guess you must have encrypted, as this particular problem is with guys who have done that. Please decrypt and disable screenlock and try reinstalling.
  16. Pankaj_Parasar
    Froyo Jan 3, 2017
  17. kolpinkb
    Cupcake Jan 3, 2017
    kolpinkb , Jan 3, 2017 :
    Still having wifi dropout issues after this update. Did a format of user data and a wipe of cache and data before and after hot fix.
    Doze is turned off too.
    Will try switching to lollipop dhcp client.
  18. doorime
    Cupcake Jan 3, 2017
  19. astuermer
    Cupcake Jan 3, 2017
    astuermer , Jan 3, 2017 :
    How to change ringtones in the 3.5.6 release?
    I have mine in folder "Ringtones" as usual. But even after a reboot only the system ringtones are shown...
    When I switch off SIM 2 now a spare SIM is shown in the statusbar. In previous release 3.1.0 the icon was just disabled when switched off.
    Any idea?
  20. Abhishek R Sharma
    Donut Jan 3, 2017
    Abhishek R Sharma , Jan 3, 2017 :
    I didn't get what you actually mean.. Can you please describe how to do this...!
