174
OxygenOS 3.5.8 (MM) OTA for OnePlus 2
  1. divinityQQ
    Honeycomb Mar 23, 2017
  2. ehsaanbhati
    Gingerbread Mar 23, 2017
    ehsaanbhati , Mar 23, 2017 :
    Agreed Security update is important.
    But Security update is not something people here are waiting for or you could see any difference in your usage with Security update
  3. themightypathan
  4. pablofg1978
    Head Moderator Head Moderator Mar 23, 2017
    pablofg1978 , Mar 23, 2017 :
    What is the point of this thread?
  5. tulip_bibs
    tulip_bibs , Mar 23, 2017 :
    Because the Marshmallow version is also not stable and the system usages the most amount of battery, no matter what you do. The device runs very laggy after hibernation, the pocket mode doesn't work. The device is getting g warm every moment. They could have fixed all this issues with a fresh build of Nougat, instead of skipping it. Will Nougat itself is better in battery and ram management than Marshmallow, so if they messed up with Nougat in 3T it's their fault. And there is no point of keeping this on Marshmallow, specially when Marshmallow isn't stable enough itself. The developers are noobs I guess, each and every build with major flaws.
  6. Leonardo Costa
    Froyo Mar 23, 2017
    Leonardo Costa , Mar 23, 2017 :
    Vibration on capacitive buttons press is no longer working and i no longer have an option to activate it, after 3.5.8 update. Anyone else having this problem?
  7. pa5t1s
    User of the Year 2014 Mar 23, 2017
    pa5t1s , Mar 23, 2017 :
    To let us know that OP2 OS 3.5.8 was downloaded?
    I was actually eagerly waiting for that info, dude made my day!
    pablofg1978 likes this.
  8. Ravi BINAVAT
    Ice Cream Sandwich Mar 23, 2017
  9. Siddhesh Vijay Kudtarkar
  10. warntjenb
    Eclair Mar 23, 2017
    warntjenb , Mar 23, 2017 :
    A Security update that won't install on encrypted devices, these guys must joking for sure... Second in a row, but since the 3.5.6. was just a fix for the 3.5.5 (which included a security patch and installed on encrypted devices JUST FINE) it was not a big problem until now. Device is save, so who cares ?
    Now the latest SECURITY update won't install on many devices... And OP does not even say it in advance, you have to try and fail. And I bet when I open a ticket, they will (again) just tell my to "wipe my phone" and shut up...:mad:
  11. F_Ángel_Enrique_bUWn
    Cupcake Mar 23, 2017
  12. JustAPhone
    JustAPhone , Mar 23, 2017 :
    Tested... there are vibration.... no issue on mine...
  13. WilfredParmar
    WilfredParmar , Mar 23, 2017 :
    Yah i know that issue. Hope oneplus update sources soon, so this problem can be solved.
    tulip_bibs likes this.
  14. Dresa91
    User of the Year 2016; Most Active User 2020 Mar 23, 2017
    Dresa91 , Mar 23, 2017 :
    And what do I have to do with it?
    Don't be so rude to all
  15. akku_aakaa
    akku_aakaa , Mar 23, 2017 :
    I doubt, though they me fix it SOON
  16. F_Kamal_Shaik_Ukgl
  17. F_Kamal_Shaik_Ukgl
  18. chirantanad
    chirantanad , Mar 23, 2017 :
    Same issue! I believe we need to format and install
    denniskp28 likes this.
  19. Vechamashok
    Donut Mar 23, 2017
  20. denniskp28
    denniskp28 , Mar 23, 2017 :
    My op2 is encrypted, when i try to install 3.5.8 i get a failure message during the reboot....
    It s absolutly stupid that the upgrade only works with unencrypted phones! How can that be?
    T2000 likes this.
