174
OxygenOS 3.5.8 (MM) OTA for OnePlus 2
  1. ShortyEx
    Ice Cream Sandwich Mar 24, 2017
    ShortyEx , Mar 24, 2017 :
    Some Indian users have reported in this thread that clearing cache works, so I suggest you try that :)
    anuraagkanodia likes this.
  2. nikhilanroid7
    Gingerbread Mar 24, 2017
    nikhilanroid7 , Mar 24, 2017 :
    Nice update. At least we have latest security patch now.
    No battery drainage
    Smooth UI
    Charging 0-100% within 2hrs
    Thanks Oneplus :)
  3. si.ananth
    Eclair Mar 24, 2017
  4. Shreekant_G
    Donut Mar 24, 2017
  5. tejasb93
    Eclair Mar 24, 2017
    tejasb93 , Mar 24, 2017 :
    Tried doing this, still it doesn't work.
  6. Erajk
    Froyo Mar 24, 2017
    Erajk , Mar 24, 2017 :
    Oh! Love updates :) I hope that battery is better. GJ OnePlus!
    (Tired of this community and whine 24/7)
    Praty_28 likes this.
  7. ShortyEx
    For something like the battery I think, and this is my opinion/expercience, you should definitely let the OS settle a bit. Install, wipe cache, use it a couple of days and see if it improves.
    But I get your frustration and motivation.
    Since you're on 3.1.0 anyway now, you could try a custom rom with better battery life (LOS, RR, Cosmic, ...).
  8. Pratip77
    Donut Mar 24, 2017
    Pratip77 , Mar 24, 2017 :
    That's the marketing strategy bro. Only then we keep changing phone and they get profited.
    kohulraj likes this.
  9. G_Madan_Singh_KJfQ
    Cupcake Mar 24, 2017
  10. Anzik
    Anzik , Mar 24, 2017 :
    No, battery drainage still exists
  11. Shreekant_G
    Donut Mar 24, 2017
    Shreekant_G , Mar 24, 2017 :
    Volte is vanished?
    Is there anybody with the same problem?
    Please help.....
    I was not having battery life issue.
    After update, Battery life is improved further.
    G_Nitin_Poddar_DmHv likes this.
  12. G_Nitin_Poddar_DmHv
  13. villa73
    villa73 , Mar 24, 2017 :
    phone would freeze at times with the old update and be in a reboot /reloop mode.
    at times, it would overheat and reboot, and with every reboot, the battery number would decrease by 5% or 10%.
    it would only usually start when i wasn't connected to WiFi or when the phone would be on 50% charge.
  14. arifmuhammed
    Froyo Mar 24, 2017
  15. MOHAN BG
  16. jordiidutch
    Eclair Mar 24, 2017
    laurboss likes this.
  17. laurboss
    Honeycomb Mar 24, 2017
  18. feniix2012
    feniix2012 , Mar 24, 2017 :
    Thank You so much for this update. My network drops have stopped.
    I live in Germany, using two SIM cards on the same network, Deutsche Telekom / D1 (one private and one from my company; one is from congstar, but as I said on the same network).
    For the past months I have had random drops from full bars to zero and calls have been dropping after a few minutes.
    First I thought it was my custom ROM, so I went back to the latest Oxygen version at the time I first noticed this problem, which was 3.5.5, which did not fix it. Nor did the older versions 3.1 and 3.0.2 (doing a clean flash of the full ROM zip including radio, firmware, etc), so I started to think it was a hardware problem, because back when those were the latest, everything had been fine. Going on, I flashed the following updates 3.5.6 and 3.5.7, but to no avail.
    I even tested version 2.2.1-2 "Hotfix update for users with Deutsche Telekom & Congstar SIMs" at one point, but of course that did not change anything either.
    This new version 3.5.8 is FINALLY working fine for me =) Now I can use this great phone again!
    rarog likes this.
  19. hardikr18
    hardikr18 , Mar 24, 2017 :
    please fix the battery problem as it drops down when fully charged within a few minutes it is drop to 80%. please bring the nougat update
  20. Gremlins
    Eclair Mar 24, 2017
    Gremlins , Mar 24, 2017 :
    Thanks for the update, happy to have the latest security patches. Have a great day guys.
