120
OxygenOS 4.0.1 (N) OTA for OnePlus 3T
  1. Rahulj1991 Gingerbread Jan 7, 2017
    Rahulj1991, Jan 7, 2017 :
    Blue led indicates u r usingdash charge
    Which u cant change
    So live with it
    Or else use another charger
    #81
  2. fcbx347 Froyo Jan 7, 2017
    fcbx347, Jan 7, 2017 :
    You got me with the rickroll for the 7.1.1 link in the readme ;)
    #82
    romanpope likes this.
  3. Rahulj1991 Gingerbread Jan 7, 2017
    Try closing last app from middle of the screen
    Its that simple
    Unfortunately if u have custom rom like RR u can customize a lot
    Not with OOS
    #83
  4. G_Raj_Kumar_QLkG Cupcake Jan 7, 2017
    #84
  5. jatink007 Gingerbread Jan 7, 2017
    #85
  6. Alexhooven1987 Gingerbread Jan 7, 2017
    Alexhooven1987, Jan 7, 2017 :
    Just download Opera VPN in the Playstore
    #86
  7. G_Alief_Patria_ZxHe Cupcake Jan 7, 2017
    G_Alief_Patria_ZxHe, Jan 7, 2017 :
    Hi! I'm new to this device. I see there's an option to update via zip file through system update in settings, but the pic in the Drive folder said that I need to flash in recovery. Does installing through manual system update works the same way? Thank you.
    #87
  8. msageer Donut Jan 7, 2017
    msageer, Jan 7, 2017 :
    I have downloaded VPN and change location but cant get any OTA latest upadate, I have 4.0 now I have downloaded 4.1 in my internal memory but manually trying it is not getting and when try boot mode it is also failed. can you help me
    #88
  9. inffy Nordics POC Assistant Head Moderator Jan 7, 2017
    inffy, Jan 7, 2017 :
    Yes there is. You need to download the zip file and put in your internal storages root folder. Then from the updater settings go to the three dot menu and there is a local upgrade option.
    #89
    otto2 likes this.
  10. G_Alief_Patria_ZxHe Cupcake Jan 7, 2017
    Thank you very much!
    #90
    otto2 likes this.
  11. Anuj_Tambe Froyo Jan 7, 2017
    Anuj_Tambe, Jan 7, 2017 :
    I am new to OnePlus family and everything looks great so far! 3T is an amazing device. 3 cheers to OP for that. And thanks for quick updates and fixes.
    #91
    ricardroido likes this.
  12. vick2214 Cupcake Jan 7, 2017
    #92
  13. Tommy6860 Honeycomb Jan 7, 2017
    Tommy6860, Jan 7, 2017 :
    If you actually have the correct one, you need to change the boot options so you can upgrade to the latest version. Go into developer options and be sure "Advanced Reboot" is turned on. Then when you long-press the power button, choose reboot, then recovery and go from there.
    #93
  14. BEARZINGA Gingerbread Jan 7, 2017
    BEARZINGA, Jan 7, 2017 :
    so AnTuTu is useless! re did the test and got the score shown below. which is higher than what I got running ver 4.0.0
    4.0.1 (Above)
    going to try the test again with my charger plugged in to see if that has anything to do with why I got a lower score
    #94
  15. rhita5 Eclair Jan 7, 2017
    rhita5, Jan 7, 2017 :
    I installed using VPN location Germany....
    #95
  16. aakash006sharma Froyo Jan 7, 2017
    aakash006sharma, Jan 7, 2017 :
    I have already got this update.
    But can you tell me - When will full image available to flash via MsmDownload Tool ?
    Please do it fast.
    #96
  17. Logan_Adams Gingerbread Jan 7, 2017
    Logan_Adams, Jan 7, 2017 :
    So there is no way to customize the position of that button.
    #97
  18. Vermiliononeplus Cupcake Jan 7, 2017
    #98
    G_Junior_Romero_GxNn likes this.
  19. mithunkhn Froyo Jan 7, 2017
    #99
  20. kkrisdal Eclair Jan 7, 2017
    kkrisdal, Jan 7, 2017 :
    I think it's good they release updates fast for issues they find. that's what they do on Google Nexus.. so updates on the fly is what I like. So I say Never Settle
