120
OxygenOS 4.0.1 (N) OTA for OnePlus 3T
  1. shatadrusp Honeycomb Jan 7, 2017
    shatadrusp, Jan 7, 2017 :
    The thing is that you just don't exactly know when to perform the test.
    Most likey, you performed the second time after rebooting the device.
  2. BEARZINGA Gingerbread Jan 7, 2017
    BEARZINGA, Jan 7, 2017 :
    nope still same boot only difference was I want charging it. I tried again while charging and it went down by 5000
  3. majkel142 Cupcake Jan 7, 2017
    majkel142, Jan 7, 2017 :
    I have the same problem on my 3T. Moreover, can anyone confirm the malfunctioning capacitive buttons? When you set the long press options it overrides the main button function.
  4. Prannay Sharma Cupcake Jan 7, 2017
  5. G_khalid_hossain_Qjzi Cupcake Jan 7, 2017
    G_khalid_hossain_Qjzi, Jan 7, 2017 :
    Is it works??
  6. ravbrar123 Gingerbread Jan 7, 2017
    ravbrar123, Jan 7, 2017 :
    it's incremental so if there's any problems it can be stopped. And since the us is one of the most important demographics, they need to be sure they don't screw anything up. I get everything first tho here in Canada so if something wrong I'm screwed but it's allg.
  7. msageer Donut Jan 7, 2017
    msageer, Jan 7, 2017 :
    I have done that when going to boot advance there is two type one is fastboot and one recovery but when I have done recovery its again showing back the same position selecting language page . don't know what to do
  8. G_khalid_hossain_Qjzi Cupcake Jan 7, 2017
    arpan2308 likes this.
  9. Steffmt Cupcake Jan 7, 2017
    Steffmt, Jan 7, 2017 :
    Hi zusammen,
    ich hoffe ich bin hier richtig. Hab mir wohl mein 3T abgeschossen. Hab das 38MB update bekommen und aufgespielt. Handy ist gerootet und TWRP drauf. Jetzt hab ich das Problem dass er immer in TWRP bootet. Hab bereits versucht das Backup zurück zu spielen, neues OS (OnePlus3TOxygen_28_OTA_037_all_1701041831_a2ba632ce9 und OnePlus3TOxygen_28_OTA_029_all_1612131737_17e7161d2b234949) zu installieren und TWRP neu zu flashen. Aber jedes mal geht er direkt wieder in TWRP. Das original Recovery wollte ich mal flashen, allerdings bringt er mir beim Download Link ein Fehler. Kann mir jemand vielleicht sagen wie ich da wieder raus komme.
    Grüße
  10. cs23kukac Cupcake Jan 7, 2017
    cs23kukac, Jan 7, 2017 :
    http://www.androidbrick.com/unbrick-oneplus-one-two-3-3t-qualcomm-hs-usb-qdloader-9008/
    Solltest versuchen. Bei mir hat das geholfen. :)
  11. jhilderbrando Cupcake Jan 7, 2017
    jhilderbrando, Jan 7, 2017 :
    Have they stopped the rollout due to play store issues and other small bugs? I have 3T in UK no update yet. I need to stay unrooted for banking apps so can't flash. If anyone knows how I can upgrade without root or wipe please let me know. Thanks!
  12. DutchDlite77 Eclair Jan 7, 2017
    DutchDlite77, Jan 7, 2017 :
    you can allready. download a vpn program like turbo vpn and set the country to germany. go to update and bam!
    Michaelnooter likes this.
  13. ShredMeister Honeycomb Jan 7, 2017
    ShredMeister, Jan 7, 2017 :
    I updated and everything was as smooth as usual. Easy and quick download using a VPN and then quick and seamless update, don't notice much difference, but then again, I didn't experience issues before.
    I want to thank the hard working developers for yet again submitting fixes and improving overall stability, always a good thing. My only feedback would be that security updates are important and I think it would have been nice to add the January one with this update. Nothing major, but yeah, that's my two cents.
    otto2 and fdroko like this.
  14. ShredMeister Honeycomb Jan 7, 2017
    it's been mentioned a thousand times... Use a VPN application, set your location to Germany or Canada and download the update, very simple.
  15. G_Supreeth_Prabhu_KaJy Cupcake Jan 7, 2017
    G_Supreeth_Prabhu_KaJy, Jan 7, 2017 :
    still no fix for Google app store
  16. G_Supreeth_Prabhu_KaJy Cupcake Jan 7, 2017
  17. F_Diganta_Koner_WIXu Jelly Bean Jan 7, 2017
  18. man sapra Eclair Jan 7, 2017
    man sapra, Jan 7, 2017 :
    post padhle... aur Vpn se download krle
  19. 2pints Honeycomb Jan 7, 2017
    2pints, Jan 7, 2017 :
    Whilst VPN is an option, why should customers have to mess around and use some arse about face means to update.
  20. Manishinde Donut Jan 7, 2017
