422
OxygenOS 4.0.2 (N) OTA for OnePlus 3
  1. F_João_Martins_qwbE
    Gingerbread Jan 26, 2017
    Android450 likes this.
  2. John j
    Jelly Bean Jan 26, 2017
    John j , Jan 26, 2017 :
    Are you pressing at the same time. Works for me Screenshot_20170126-182753.png
  3. cmitchellshaw
    KitKat Jan 26, 2017
    cmitchellshaw , Jan 26, 2017 :
    Do a full wipe and set the phone back up. Moving from MM to N needs a full wipe to get running correctly.
  4. Android450
    Marshmallow Jan 26, 2017
    Android450 , Jan 26, 2017 :
    you shouldn't have any issues with lag now
    cmitchellshaw likes this.
  5. pradha91
    Honeycomb Jan 26, 2017
    pradha91 , Jan 26, 2017 :
    Sure ..
    1) report in correct forum
    2) be more clear on whats the issue while reporting.
  6. ironass
    Lollipop Jan 26, 2017
    ironass , Jan 26, 2017 :
    Is this after you have cleared your phone's cache partition and Factory Reset it, as per numerous posts in this thread?
  7. Bobbie63
    Nougat Jan 26, 2017
    Bobbie63 , Jan 26, 2017 :
    First of all, I am wondering what device you have, OP3 or OP3T, as you've posted in a thread for OP3T previously and secondly, I was wondering what you have already tried yourself to fix the issues? By reading, you already can fix the majority of th e problems.
    Chung-yu Liao, Sun90 and ironass like this.
  8. ruhela786
    Ice Cream Sandwich Jan 26, 2017
    ruhela786 , Jan 26, 2017 :
    This update has really started to piss me off, don't know why this Android system is consuming battery, any suggestion guys what should i do?? should i perform a factor data reset or a hard reset from recovery??
  9. palash.shah
    Donut Jan 26, 2017
    palash.shah , Jan 26, 2017 :
    I got a 34MB update for Oxygen OS 4.0.2. I downloaded it and installed but when mobile rebooted, it asked for the location of update. I couldn't find so I cancelled and when it rebooted and I checked, it showed a 1.4GB update. A shock, but I started downloading. From last 4 days it has stopped at 71.3%. What should I do? How can I can I cancel the download and restart from 0%?
  10. Bobbie63
    Nougat Jan 26, 2017
    xcrm likes this.
  11. Bobbie63
    Nougat Jan 26, 2017
    View attachment 491230 [/QUOTE]
    Go to settings> apps ,once there hit the three dot menu over flow and select system apps.
    Then scroll down to find "system update" app then open it and clear data/ cache of the same, after that check again for update.
    With special thanks to @Sun90
  12. Bobbie63
    Nougat Jan 26, 2017
    Have you tried it running the device in safe mode for a day?
    ghostofcain and ironass like this.
  13. ruhela786
    Nope
  14. Bobbie63
    Nougat Jan 26, 2017
    Can't promise it will work, but might be worth a try, could be some third party app is somehow using resources of Android and not showing it. I understand that for instance Facebook is a star in hiding for the battery status so probably could be one or the other app.
    ironass likes this.
  15. pranavpathakk
    Cupcake Jan 26, 2017
    pranavpathakk , Jan 26, 2017 :
    Sir, there are a few issues I am facing with my camera actually.
    Both my cameras have very low light optimisation. Actually when it comes to clicking pictures in the dark, even with flash my camera shows very dark pictures and videos.
    Also, my room has very less lighting. So everytime I use my camera, in low light it only shows dark pictures. please help.
  16. pranavpathakk
  17. ruhela786
    i haven't installed Facebook and messenger on my phone, actually the thing is i was not getting good sot with this update and i thought that i updated it through ota so that might be the reason so i decided to download the rom and flash it and i did that but after that i was facing lags while scrolling notifications and phone was not running smoothly so 15 minutes earlier i did a factory data reset now let's see if some problem occurs or not if it does then will do a hard reset. Anyways thanks for the reply my friend :) .
    Sun90 likes this.
  18. Alpha Mike Foxtrot
    KitKat Jan 26, 2017
    Alpha Mike Foxtrot , Jan 26, 2017 :
    My bad. I misread the intent.
  19. Bobbie63
    Nougat Jan 26, 2017
    Your welcome, but i already somehow got the idea you wouldn't have Facebook, it was just meant as an example of an app the is sucking the sh.. out of batteries without showing it. Other apps could do even so. Running the device in safe mode should rule out third party apps. But as you already performed the reset, my suggestion is a little late but might help others, when they might (probably wishful thinking) read this:rolleyes:
  20. Varunkanth
