422
OxygenOS 4.0.2 (N) OTA for OnePlus 3
  1. ghostofcain
    Marshmallow Feb 7, 2017
    ghostofcain , Feb 7, 2017 :
    No, it's the wipe after installation that's important, saying that if you aren't having issues stick with it.
    cmitchellshaw likes this.
  2. andrej666op
    Cupcake Feb 7, 2017
    andrej666op , Feb 7, 2017 :
    Fingerprint sensor is slower than usual also the touch latency still occurs we need 4.0.3 asap.
  3. Auristic
    KitKat Feb 7, 2017
    Auristic , Feb 7, 2017 :
    Wipe cache, if it continues factory reset then come back and say thank you!
  4. andrej666op
    Cupcake Feb 7, 2017
    lol Ive tried everything..
  5. ghostofcain
    Maybe you have a hardware problem then as I notice no difference in fingerprint reader from mm and touch latency has never been an issue on my OnePlus 3.
  6. sroy001
    Donut Feb 7, 2017
    sroy001 , Feb 7, 2017 :
    Battery life on 4.0.2 Nougat OTA is very poor. I'm experiencing major idle battery drain. Almost 10-15% overnight and throughout the day as well. What good is aggressive doze mode and all the silly optimisation if it can't even prevent idle overnight battery drain?? Earlier I would finish my day at 50-60% on MM now on Nougat 20-30% which is very poor. Tried factory reset, cache, clean install and even Greenify paid and everything but no avail.
  7. andrej666op
    Cupcake Feb 7, 2017
    Depends how fast you type,seen lots of topics about the latency.
  8. xcrm
    Ice Cream Sandwich Feb 7, 2017
    xcrm , Feb 7, 2017 :
    YOU need 4.0.3 asap, not WE. I have no problem with the fingerprint sensor.
  9. ghostofcain
    Seen lots of talk about latency but they all seem to be spouting unsubstantiated bs, obviously that's just my opinion.
  10. andrej666op
    Cupcake Feb 7, 2017
  11. ask0234
    Donut Feb 7, 2017
  12. xcrm
    Delete old fingerprints from settings, wipe cache, wash your hands and take new fingerprints.
  13. Auristic
    KitKat Feb 7, 2017
    Obviously not...
  14. andrej666op
    Cupcake Feb 7, 2017
  15. ask0234
    Donut Feb 7, 2017
    ask0234 , Feb 7, 2017 :
    is there anyone facing the calling problem from contact list???
    or having solution to it.
  16. ghostofcain
    No, but it's nothing a cache wipe or factory reset won't fix.
    cmitchellshaw and Auristic like this.
  17. Auristic
    KitKat Feb 7, 2017
    Then you didn't RMA your phone because if you'd done so your problem would already be solved...
    Unless you want to keep on whining here and do nothing...
    thomas riche, xcrm and ghostofcain like this.
  18. andrej666op
    Cupcake Feb 7, 2017
    why would I return my phone lmao it was perfectly fine before Nougat....
  19. Auristic
    KitKat Feb 7, 2017
    Then go back to 3.2.8... See, each problem has its solution...
    ironass, xcrm and ghostofcain like this.
  20. F_Cédric_Catonyme_mwQu
    Cupcake Feb 7, 2017
