422
OxygenOS 4.0.2 (N) OTA for OnePlus 3
  1. Rishabh 1603
    Donut Jan 18, 2017
  2. Aymahalawa
    Froyo Jan 18, 2017
    Zh_kilat likes this.
  3. ankitttt
    Honeycomb Jan 18, 2017
    tejaslrajput likes this.
  4. G_Ion_Caimacan_hgAw
    Cupcake Jan 18, 2017
  5. G_Aman_Raj_LTYW
    Eclair Jan 18, 2017
  6. mharis
    Ice Cream Sandwich Jan 18, 2017
  7. ghostofcain
    Marshmallow Jan 18, 2017
    ghostofcain , Jan 18, 2017 :
    Update patch failed to apply, could be for any number of reasons so full rom zip now downloading to flash full rom. That's what is supposed to happen.
    Nasty, makes it impossible to upload images.
    That's what it says in release notes.
    Not necessarily it could be regional. Apparently India is quite a large country.
    Sun90 likes this.
  8. ricardroido
    Froyo Jan 18, 2017
    ricardroido , Jan 18, 2017 :
    the OP3 was the first thread I came across when it was mentioned not the OP3T . it took a while for the latter to appear when I was searching for it
    as for you saying the first few hours there was 14 minutes between the 3T and 3 posts going live . so your exaggeration is not warranted
    apologies to anyone this may have confused if indeed it did for any reason
  9. Kmaryanski
    Eclair Jan 18, 2017
  10. G_Charan_Teja_tpIs
  11. Himanshu Ramteke
    Eclair Jan 18, 2017
  12. re02am
    re02am , Jan 18, 2017 :
    Germany
  13. mharis
    mharis , Jan 18, 2017 :
    If it doesn't say it in the release notes then it must not have changed.
    BTW OnePlus haven't accepted it as a bug, they say it is this way 'by design'.
  14. mtbgus
    mtbgus , Jan 18, 2017 :
    Maybe shows a lack of intelligence in a lot of those who own a 3T, that they don't understand the different or they're unable to understand the simple basic way the forum is set out under ...op2...op3....op3T!!!
    xcrm and Sun90 like this.
  15. G_Jannick_Vervoorn_udYv
    G_Jannick_Vervoorn_udYv , Jan 18, 2017 :
    cant login with macdonalds WiFi because the phone wont sent me toch the webpage of macdonalds to login! in marshmallow i always got a notification to login on the WiFi!
  16. G_Robert_Kovacs_LoOy
    Froyo Jan 18, 2017
    G_Robert_Kovacs_LoOy , Jan 18, 2017 :
    When you try and access a page in the web browser you should be automatically redirected. Happened to me on 3.2.8 as well.
  17. Pushkar Kashyap
    Pushkar Kashyap , Jan 18, 2017 :
    Updated to OxygenOS 4.0.2. Still not able to download or update apps from Google play store while ROAMING.
    anilchelli likes this.
  18. azeez4901
    azeez4901 , Jan 18, 2017 :
    Already got it from Canada last night.. thanks tho
  19. atulalvenkar
    atulalvenkar , Jan 18, 2017 :
    Then it looks like it's a problem with Jio rather then the firmware. Jio is not fully stable yet and lot of issues crop up. Try using some other operator and see if it works.
  20. azeez4901
    Wipe play store and play services data and cache.. reboot recovery and wipe device cache.. reboot
