205
OxygenOS 4.0.2 (N) OTA for OnePlus 3T
  1. G_Aapoorv_Malpekar_SsCF
    Froyo Jan 18, 2017
    G_Aapoorv_Malpekar_SsCF , Jan 18, 2017 :
    for the fingerprint issue try setting the same finger in different angles for multiple stored finger ie: Same finger for Fingerprint 1..2..3.4..5. i had the same issue and it worked for me
    davydavy888 likes this.
  2. decahillane
    Froyo Jan 18, 2017
    decahillane , Jan 18, 2017 :
    Find the post in this thread for a link to 30mb incremental update file. Place in download folder and boot into recovery, choose update and find the file. Boom.
  3. partharaj
    Donut Jan 18, 2017
    partharaj , Jan 18, 2017 :
    Here's what I've noticed w.r.t to Battery drain. Somehow I feel it is related to dual SIM than anything.
    When on 4.0.1 Dual SIM enabled
    - 1% battery drain for every 3 minutes of usage
    - 1% battery drain for every 10 minutes of non usage
    When on 4.0.1 with just 1 SIM activated
    - 1% battery drain for every 10 minutes of usage
    - 1% battery drain for every 1 hour of non usage
    Now on 4.0.2 Dual SIM enabled
    - 1% battery drain for about 30-45 minutes of non usage
    Now on 4.0.2 with just 1 SIM
    Tried everything that were suggested on the forums w.r.t to removing apps, factory reset, etc. OP - looking for your feedback. Thanks in advance!
    manapon, prav33nchandar and fdroko like this.
  4. partharaj
    Donut Jan 18, 2017
    As you can see, using 2 SIMs is 3 times worser during screen on usage. I have no complaints on battery whatsoever when 1 SIM only used.
    Does anyone else have the same issue?
  5. MCzolkos
    Donut Jan 18, 2017
    MCzolkos , Jan 18, 2017 :
    okay thx, but system is stable, I do not actually have to do the update. I am on stock. Update should be running automatically shouldn't it?
  6. 730dip
    Cupcake Jan 18, 2017
    730dip , Jan 18, 2017 :
    Battery drains faster for me on 4.0.2....
    Can anyone else confirm??
    validator771100 likes this.
  7. Ian_F
    Gingerbread Jan 18, 2017
    Ian_F , Jan 18, 2017 :
    Not required. I've one fingerprint stored in each of them. So 5 different fingers. You just need to keep changing your finger position and angle as you're teaching your phone each finger. Do not dab the exact same way twice else you're wasting "slots"
  8. Deactivated User
    Jan 18, 2017
  9. Ian_F
    No one can as the update has only been out for 24 hours.
  10. jagannathbelel
    jagannathbelel , Jan 18, 2017 :
    Still battery drain issues is there and WiFi issues still present as it is been mentioned,
    Huge lag while expanding the notification bar and front camera facing issues to focus
  11. kimjay
    Donut Jan 18, 2017
    kimjay , Jan 18, 2017 :
    I'm still on 3.5.3
    Build number: A3010_28_161122
    Do i still have to tunnel through Canada or something to get the update via OTA?
    I'm wondering if the builds on OTA are for model specific? eg: I got the A3010 model, will receiving an OTA (tunneling to Europe) that's intended for A3003 will be any different ?
  12. SumanGhosh1992
  13. Mr.Miller
    Eclair Jan 18, 2017
    Mr.Miller , Jan 18, 2017 :
    Every time i try to change my wallpaper of my lockscreen its says : couldn't load photo. I did a clean install wiped cache everything, still didn't work.
    My phone is on 4.0.1 is this fixed in 4.0.2
    Please help ! thank you
  14. elHeroe
    Eclair Jan 18, 2017
    elHeroe , Jan 18, 2017 :
    No. Smartphone pairing fine with car's BT, but a few minutes after pair crash connection. And BT (car) is disabled, And i have restart car ...
    I'm sorry my english
  15. partharaj
    Donut Jan 18, 2017
    Do you use 1 SIM or 2?
  16. dhirajvarma
  17. fommuz
    fommuz , Jan 18, 2017 :
    Can I ask you where you got this incremental update file? :)
    Does OnePlus offer it somewhere?
    Greets.
  18. HoriaRave
    Froyo Jan 18, 2017
  19. andersen88
    andersen88 , Jan 18, 2017 :
    I'm based in the UK and just wondering when I can expect to receive the Nougat update for my 3T?
    N.B current on version: 6.0.1 and OxygenOS version: 3.5.4.
    Thanks in advance!
  20. onedeep
