380
OxygenOS 4.0.3 (N) OTA for OnePlus 3
  1. Teovu Cupcake Feb 17, 2017
    Teovu, Feb 17, 2017 :
    Someone help, after New update my Phone is slower, the apps are turning on slower etc
  2. Atin Deval Cupcake Feb 17, 2017
  3. Sun90 Lollipop Feb 17, 2017
    Sun90, Feb 17, 2017 :
    Do check first post of this thread.
    cmitchellshaw, xcrm, Jole7 and 3 others like this.
  4. Sun90 Lollipop Feb 17, 2017
    Reboot to recovery and perform a cache wipe and then see.
  5. ghostofcain KitKat Feb 17, 2017
    ghostofcain, Feb 17, 2017 :
    Reading and searching are your friends.
    cmitchellshaw, xcrm, zoran81 and 2 others like this.
  6. ravishankar shanmugam Cupcake Feb 17, 2017
    ravishankar shanmugam, Feb 17, 2017 :
    thank you
    xcrm likes this.
  7. Star Lord Honeycomb Feb 17, 2017
    Star Lord, Feb 17, 2017 :
    Recently updated to new version. Found a few bugs.
    1)Video utility Max Player both picture and sound freezes for a few seconds while playing movie.
    2)The Auto Ambient light is considerably slow to respond while adjusting the brightness levels from dark to bright and vice versa.
    3)Experienced slowness on Volte data. (Jio Sim service)
    I will post if any other significant bug found other than the above mentioned.
    Archies likes this.
  8. G_Jayesh_Shivji_DcxF Cupcake Feb 17, 2017
    Archies likes this.
  9. SoniaB Nougat Senior Moderator Feb 17, 2017
    SoniaB, Feb 17, 2017 :
    Thread merged.
    xcrm, Sun90 and ghostofcain like this.
  10. F_Tom_Baars_aGYR Cupcake Feb 17, 2017
    F_Tom_Baars_aGYR, Feb 17, 2017 :
    hi, I have some trouble updating my OS. Every time I try, the phones reboots and starts in the BIOS where I reboot it again. Then I am back at the beginning and a error message from a failed update.
    please help!!
  11. Alpha Mike Foxtrot KitKat Feb 17, 2017
    Alpha Mike Foxtrot, Feb 17, 2017 :
    It seems that you had a corrupt install of the update file.
    1. Go to the downloads section and download the zip file for 4.0.3
    2. Take a backup of the phone
    3a. Either connect phone to laptop and adb sideload the file
    3b. Or Put that file on the Root Directory and Go to recovery menu, navigate to the Install local file option
    4. Clear everything on the phone (You should have taken a backup before this step)
    5. Get back to us if it helps, or even if it doesn't
  12. G_Anuj_Chandrawanshi_SVF Eclair Feb 17, 2017
  13. zoran81 Jelly Bean Feb 17, 2017
    zoran81, Feb 17, 2017 :
    Do an update
  14. zoran81 Jelly Bean Feb 17, 2017
    OOS 4.0.3 is so good that I don't know what OP could improve in the next update
    cmitchellshaw, ironass and Sun90 like this.
  15. nshah972 Eclair Feb 17, 2017
  16. _saurabhkadam_ Cupcake Feb 17, 2017
    _saurabhkadam_, Feb 17, 2017 :
    bug observed in whatsaap. when I switch no my mobile data or my WiFi for the first time I start receiving all my whatsaap message in my notification bar. but when I click on it the whatsaap dosent open up and the notification just be there as it is I have to open the app manually through the app drawer. This happens only when I switch on my wifi or mobile data a long time and when there are many unread whatsapp messages pending. please look into this bug soon and provide with a new update
  17. -error Froyo Feb 17, 2017
    -error, Feb 17, 2017 :
    In my case it is worse than it was in 4.0.2
  18. ghostofcain KitKat Feb 17, 2017
    Very first post in this thread not read?
    Issue with WhatsApp, report to WhatsApp developers.
    cmitchellshaw, xcrm and Sun90 like this.
  19. rahulk86 Cupcake Feb 17, 2017
    rahulk86, Feb 17, 2017 :
    What i have done?
    1. wiped cache
    2. reset network settings
    3. swapped sims from slot 1 to 2 and back
    4. uninstalled and installed back MyJio app
    5. enabled "VoLTE provisioned" in phone info (*#*#4636#*#*)
    Nothing worked. what else left to do?
    I have update 4.0.2 from Canada VPN and 4.0.3 from India OTA.
  20. Sun90 Lollipop Feb 17, 2017
    The solution I gave didn't work.
