380
OxygenOS 4.0.3 (N) OTA for OnePlus 3
  1. zoran81 Jelly Bean Feb 17, 2017
    zoran81, Feb 17, 2017 :
    Hard reser
    cmitchellshaw and Bobbie63 like this.
  2. rex.recca Eclair Feb 17, 2017
    rex.recca, Feb 17, 2017 :
    I am. Still facing issues in using the playstore while on romaing. Can anybkdy suggest a solution for this??
  3. Sun90 Lollipop Feb 17, 2017
    Sun90, Feb 17, 2017 :
    There is no solution for now.
    U have to rely on Wi-Fi till Google sorts it out.
    ghostofcain and Bobbie63 like this.
  4. G_Anirudh_verma_axZa Donut Feb 17, 2017
    G_Anirudh_verma_axZa, Feb 17, 2017 :
    I have done the same and went to service center as well...they downgraded my software to Marshmallow with Oxygen 3.2.2...below are the updated results
  5. G_Anirudh_verma_axZa Donut Feb 17, 2017
  6. Coolone73 Cupcake Feb 17, 2017
    Coolone73, Feb 17, 2017 :
    Since New updates my Jio Sim is not working.is anyone facing this issue and any possible resolution. Data is working fine but calls are not going through.
  7. zoran81 Jelly Bean Feb 17, 2017
    If you read carefully you'll find that there is more than few people with the same issue..and if you continue to read maybe you'll find the solution..Mr. Mulder once said "truth is out there"..so never stop searching..
  8. maecal Cupcake Feb 17, 2017
    maecal, Feb 17, 2017 :
    oneplus3 Users Feature does not work anymore after the update android 7
    please fix this problem in the next patch
    this Feature so Important
    i can't click on my old user
    thank you
  9. VinayML Gingerbread Feb 17, 2017
  10. Alpha Mike Foxtrot KitKat Feb 17, 2017
  11. kalander Shihab Ice Cream Sandwich Feb 17, 2017
    kalander Shihab, Feb 17, 2017 :
    Currently in lineage OS and I should say the animations in lineage OS is so much smoother. Like you notice the difference significantly smoother compared to oxygen OS
  12. THEHARDIK Eclair Feb 17, 2017
  13. G_doddi_jagadeesh_xPDW Cupcake Feb 17, 2017
  14. US@18 Cupcake Feb 17, 2017
    US@18, Feb 17, 2017 :
    Hello All! I got the One Plus 3 oxygen os 4.0.3 update now.. So, give me an advice that should I update it or not..???
    zoran81 likes this.
  15. camohan Lollipop Moderator Feb 17, 2017
    camohan, Feb 17, 2017 :
    Thread merged, feel free to get opinions in main thread.
    Sun90 and US@18 like this.
  16. US@18 Cupcake Feb 17, 2017
    What are the issues happening with this latest update of oxygen os 4.0.3??
  17. johnalongi Cupcake Feb 17, 2017
    johnalongi, Feb 17, 2017 :
    Is anyone having an issue with the Amazon Music app not working? Mine doesn't load and says there's a connection error and to check my Wifi or cell signal connection. Well, my cell connection works perfectly fine just the app doesn't load. I tried restarting the device, clearing the cache, and uninstalling/reinstalling the app and it still doesn't work.[​IMG]
  18. xcrm Ice Cream Sandwich Feb 17, 2017
    xcrm, Feb 17, 2017 :
    Read message #1 in this thread.
  19. Alpha Mike Foxtrot KitKat Feb 17, 2017
    cmitchellshaw, xcrm, zoran81 and 3 others like this.
  20. Sun90 Lollipop Feb 17, 2017
    Yes, A ton of work which no cupcake relish.
    cmitchellshaw, zoran81, xcrm and 2 others like this.
