380
OxygenOS 4.0.3 (N) OTA for OnePlus 3
  1. AgarPiyush
    Froyo Feb 9, 2017
  2. Kiran.a.joseph
    Jelly Bean Feb 9, 2017
    Kiran.a.joseph , Feb 9, 2017 :
    91 mb would be the patch update.
    The 1.4 gb is the full build file
  3. amb67
    Gingerbread Feb 9, 2017
  4. AgarPiyush
    Froyo Feb 9, 2017
    AgarPiyush , Feb 9, 2017 :
    It was 91 mb for me too. For some reason installation failed. Now it's showing 1440 mb
  5. YacoSE
    Froyo Feb 9, 2017
    YacoSE , Feb 9, 2017 :
    after using 4.0.3 for an hour I feel it same smooth than 4.0.2 just installed... I don't think that devs touched latency yet
    Jole7 and kevonn95 like this.
  6. AgarPiyush
    Froyo Feb 9, 2017
    Should I proceed with 1.4GB update?
    cmitchellshaw likes this.
  7. Kiran.a.joseph
    I already updated to 4.0.3 an hour back
    Go ahead and update
  8. AgarPiyush
    Froyo Feb 9, 2017
    Updating with full build file doesn't factory reset? Right?
  9. Kiran.a.joseph
    It doesn't
  10. kevonn95
    Honeycomb Feb 9, 2017
    kevonn95 , Feb 9, 2017 :
    Wiped all you can imagine, cache, apps, reboot, etc... no solution, last thing to do is factory reset :(
  11. saadnagi
    Cupcake Feb 9, 2017
    saadnagi , Feb 9, 2017 :
    I just did and everything looks fine thanks alot for your help.
    abhishekkapoor81 likes this.
  12. Marek Brieger (Polmabri)
    Cupcake Feb 9, 2017
  13. xcrm
    Ice Cream Sandwich Feb 9, 2017
    xcrm , Feb 9, 2017 :
    Do you read something in the first message about battery usage?
  14. xcrm
    And i think you are not in India.
  15. gado45
    Eclair Feb 9, 2017
    gado45 , Feb 9, 2017 :
    90mb OTA failed for me too.. Does the full 1.4gb flash wipes everything ?
  16. xcrm
    What do you think about the forum when everybody sends the same picture about the same update.?
    A large forum maybe?
    ghostofcain likes this.
  17. Javi
    Donut Feb 9, 2017
    Javi , Feb 9, 2017 :
    Just downloaded.. I hope it solves the heat and battery drain issues..
    Kentcchoong likes this.
  18. petkyrk
    Donut Feb 9, 2017
    bulletmark likes this.
  19. playerboys
    Froyo Feb 9, 2017
    playerboys , Feb 9, 2017 :
    no
    gado45 likes this.
  20. you_weee
