380
OxygenOS 4.0.3 (N) OTA for OnePlus 3
  1. Asumos
    Ice Cream Sandwich Feb 9, 2017
  2. sroy001
    Donut Feb 10, 2017
    Mehran_Singh_Katoch likes this.
  3. Techder
    Ice Cream Sandwich Feb 10, 2017
    Techder , Feb 10, 2017 :
    I never have faced that maybe you are family of the flash then offcourse everything is to slow ;)
  4. Sajidmib
    Eclair Feb 10, 2017
    cmitchellshaw likes this.
  5. petkyrk
    Donut Feb 10, 2017
    petkyrk , Feb 10, 2017 :
    that's good to know my friend. I also send a bug report and hope that they will address it. I also was disappointed when I saw that there is no mention on 4.0.3 changelog for android pay.
  6. Sajidmib
    Eclair Feb 10, 2017
  7. f5oci3ty
    Eclair Feb 10, 2017
  8. Zh_kilat
    Android Q Feb 10, 2017
    Zh_kilat , Feb 10, 2017 :
    flash the full rom zip ...
  9. Layne911
    Cupcake Feb 10, 2017
    Layne911 , Feb 10, 2017 :
    Having issues installing the OTA, downloaded 3 times everytime it boots and goes to safe mode I can find it manually but when I click on the file the unlock is different than mine. What can I do?
  10. acyix
    Froyo Feb 10, 2017
    acyix , Feb 10, 2017 :
    Okay, so the past two OTAs have been failing to update for me (4.0.2 and 4.0.3). It does its thing and resets my phone, but boots into recovery and doesn't update. I've never rooted my phone and always did OTA updates without a VPN (I'm from Canada).
    It always starts with the smaller update, then fails and directs me to a 1.4 GB update and that fails too. What annoys me is that it just took up 1.4 GB of my bandwidth and it failed -_-
    Guess I'll have to update via the zip file, it's the only work around. Albeit a bit annoying, and I'm sure I'm not the only one with these issues.
    OTAs have always been smooth for me except the last two. Have sent the logs since the OP team contacted me last time about 4.0.2. Guess the update problem is still not fixed.
  11. acyix
    Froyo Feb 10, 2017
    Download the zip and update in the recovery manually... Save your data, it's going to keep failing if you try the OTA. A couple people already posted the zip, check a few pages before this.
    Layne911 likes this.
  12. niteshkumar.nic
    Froyo Feb 10, 2017
    niteshkumar.nic , Feb 10, 2017 :
    Hmm vpn bro [e]1f44d[/e] [e]1f44d[/e] [e]1f44d[/e] [e]1f44d[/e] [e]1f44d[/e]
  13. Odl
    Gingerbread Feb 10, 2017
    Odl , Feb 10, 2017 :
    First does your carrier allows OnePlus 3 phone to use VoLTE?, they control which phones have access to it.
    Second to activate it you need to add this in build prop, in case you do not already have it
    #ifdef VENDOR_EDIT
    persist.dbg.ims_volte_enable=1
    persist.dbg.volte_avail_ovr=1
    persist.dbg.vt_avail_ovr=1
    persist.data.iwlan.enable=true
    persist.dbg.wfc_avail_ovr=1
    #endif
    ushaikh648 likes this.
  14. fazilm
    Donut Feb 10, 2017
    fazilm , Feb 10, 2017 :
    Install Opera VPN -> Connect to Canada Region-> Check For Update and you should have 4.0.3
  15. fazilm
    Donut Feb 10, 2017
    Use Opera VPN-> Connect to Canada Region-> And you should have the Update
  16. fazilm
    Donut Feb 10, 2017
    Use Opera VPN from Play Store-> Connect to Canada Region-> You Should have the Update
  17. fazilm
    Donut Feb 10, 2017
  18. ritesh808
    Honeycomb Feb 10, 2017
    ritesh808 , Feb 10, 2017 :
    Set VPN to Hong Kong. I've got both 4.0.2 and 0.3 within few hours of release.
  19. ritesh808
    I'm actually in HK, so I know it's released to HK in the first batch.
  20. beng0804
    Eclair Feb 10, 2017
    beng0804 , Feb 10, 2017 :
    Double tap home button to open Camera show unknown error after update to 4.0.3
