591
OxygenOS 4.0 (N) OTA for OnePlus 3
  1. oeoeoe
    Cupcake Jan 1, 2017
    oeoeoe , Jan 1, 2017 :
    I got major problems after the update.
    Phone is not responding after stand by most of the time and needs to be rebooted.
    Sometimes double click on on/off button activates the camera app. Then I can reach the surface again.
    Sometimes it just doesn't respond at all for 4 to 5 seconds while I use it.
    Very annoying.
    It is the second time already I had major problems after an OTA update.
    First time my OPO phone even was bricked.
    Do you guys test updates at all?
  2. Bender64
    Donut Jan 1, 2017
    Bender64 , Jan 1, 2017 :
    Update is ok but :
    - no alarm time on proximity wake screen ??? RLY ? :mad:
    - when i scroll ( settings, dialer, aps ) i have lags but only when i have finger on screen, if i fast swipe on screen, scrooling is smooth from moment when i do not touch screen
    - no more red color in theme settings :(
  3. ringogelso
    Gingerbread Jan 1, 2017
    ringogelso , Jan 1, 2017 :
    from settings, slider Of notifications, select silent and turn vibration. Now when you silent selection by the cursor will be only the vibration ..
    ghostofcain likes this.
  4. andremello
    Eclair Jan 1, 2017
    andremello , Jan 1, 2017 :
    Can not say exactly, but it was not that long. About 10 minutes maybe. Regarding the download, I changed the country to Canada using opera VPN as suggested and everything worked just fast and fine.
  5. G_Mayur_Kale_IDgo
  6. puneet.bansal
    Cupcake Jan 1, 2017
  7. Alpha Mike Foxtrot
    KitKat Jan 1, 2017
    Alpha Mike Foxtrot , Jan 1, 2017 :
    Then ask the right questions?
    It takes about 10 minutes, but might take longer based on the number of apps you have to download.
    Also, stop asking the same question again and again.
    srlawren, Spelt and Sun90 like this.
  8. Spelt
    Ice Cream Sandwich Jan 1, 2017
    Spelt , Jan 1, 2017 :
    Same mine is perfect. I also did a complete reset and format to get f2fs file format in my data partition. To change a file format in a partition formatting is necessary.
    Sun90 likes this.
  9. Sun90
    Starting Point Expert Jan 1, 2017
    Sun90 , Jan 1, 2017 :
    Backup everything and do a factory reset.
    As it is always needed with a major update.
  10. k20197
    Cupcake Jan 1, 2017
    k20197 , Jan 1, 2017 :
    I am soon gonna post a thread on how to get the OTA even if it is not released in your country yet....check it out
  11. G_Steve_Turner_GYMh
    Cupcake Jan 1, 2017
  12. NeroTheDawn
    Cupcake Jan 1, 2017
  13. Sun90
    No issues.
  14. Kalid1999
    Cupcake Jan 1, 2017
    Kalid1999 , Jan 1, 2017 :
    can u guys tell us the estimated time for the roll out of Android n for op 2?
  15. tejaslrajput
    tejaslrajput , Jan 1, 2017 :
    Now again did it as u said, I am now on F2FS. Thanks!
  16. shubhamb08
    Froyo Jan 1, 2017
    shubhamb08 , Jan 1, 2017 :
    I have issues with playstore. If I start a download on mobile data, it's stuck on downloading and if I start the download with wifi and switch to data in between the download it says waiting for network, even though the mobile data is on. So basically playstore apps download/update via mobile data is impossible. I am on (national) roaming btw. I know people were having this issue in OB, how do I fix this? I can't go through thousand of posts, if this is already answered please point me to the post number.
  17. kartik104
    Eclair Jan 1, 2017
  18. abhadra96
    Froyo Jan 1, 2017
    abhadra96 , Jan 1, 2017 :
    for tech enthusiast's like me.. nothing can be better than this
  19. bjorg18
    bjorg18 , Jan 1, 2017 :
    Anybody knows how to change icon from 4G to LTE? Or is it not doable? LTE icon was so cool. By the way, loving this update. So far so good.
  20. dgaspa75
    Froyo Jan 1, 2017
    dgaspa75 , Jan 1, 2017 :
    Same as Nexus/Pixel. Go to recents and drag the app to top and then select the app on bottom. Most of apps support split screen. But some still don't.
    Jolemi likes this.
