591
OxygenOS 4.0 (N) OTA for OnePlus 3
  1. kalander Shihab
    Jelly Bean Jan 2, 2017
  2. F_Shafi_Mjri_prUM
    Eclair Jan 2, 2017
    F_Shafi_Mjri_prUM , Jan 2, 2017 :
    Need bug fixes for Oxygen 4 Nougat and there is so many frame rate missing also. Especially you can see this when we opens the WhatsApp from the notification panel and when you opens the Google search bar at the home screen
  3. F_Devraj_Swain_JGht
    Gingerbread Jan 2, 2017
    F_Devraj_Swain_JGht , Jan 2, 2017 :
    use alert slider to silent mode (Setting<alert slider<silent then check vibration)
    rarog likes this.
  4. rarog
    Assistant Head Moderator Assistant Head Moderator Jan 2, 2017
    Sun90 likes this.
  5. G_Roy_van_Akkeren_XvOU
    Cupcake Jan 2, 2017
    G_Roy_van_Akkeren_XvOU , Jan 2, 2017 :
    After updating to Nougat I got the Audio tuner option. Cool! But..... It doesn't do anything!!!! The sound doesn't change. I used an equalizer app on Marshmallow and this don't work either anymore.
    Do you experience the same? And does someone know a fix? Please help.
  6. F_Devraj_Swain_JGht
    Setting<button<recent button<long press action then enable open/close split screen
  7. F_Devraj_Swain_JGht
    use headphone for better sound experiance
  8. c4rnal
    Froyo Jan 2, 2017
    c4rnal , Jan 2, 2017 :
    Any one else having notification issues? The LED dont light up when i get a snapchat message for instance and the phone doesnt vibrate. I have to wake the screen to see if i have anything new. Its like this regardless of where i have the alert slider. I have made sure that notifications are enabled for all the apps that i use.
    bjorg18 likes this.
  9. esecchi
    Donut Jan 2, 2017
    esecchi , Jan 2, 2017 :
    Does anyone have the same issues / has anyone found a fix for the missing space that pops up to write text when sending a photo in WhatsApp?
    This appears to only happen when sending a photo taken in WhatsApp - It used to appear above the suggestions and now I can only see what I am writing if i remove the keypad. Started since last night following upgrade to Nougat.
    Any help greatly appreciated.
  10. himzz13
    Donut Jan 2, 2017
    himzz13 , Jan 2, 2017 :
    is the apps auto launch and aggressive dose available in this update..??
  11. F_Devraj_Swain_JGht
    configure wifi setting in phone (setting<wifi<setting) or check advance setting choose wifi frequency band (2.5ghz or 5ghz) which your router support
    might this solution will help you
    btw oneplus use cheap wifi data card
  12. F_Devraj_Swain_JGht
    setting<battery<aggresive dose then disable snapchat
  13. Karan31951
    Cupcake Jan 2, 2017
  14. F_Devraj_Swain_JGht
    change keyboard color might help you
  15. Sayan Roy
    Sayan Roy , Jan 2, 2017 :
    Does anybody get the Nougat update in India without using any VPN service?????
  16. G_Nirav_Zaveri_fxUQ
    Froyo Jan 2, 2017
  17. F_Devraj_Swain_JGht
    no.... not yet
    Sayan Roy likes this.
  18. F_Devraj_Swain_JGht
    nooo no need to do factory reset
    G_Nirav_Zaveri_fxUQ likes this.
  19. SahilQureshi
    Honeycomb Jan 2, 2017
    SahilQureshi , Jan 2, 2017 :
    An apparent lag is there when you touch mobile data shortcut for turning on/off data. I don't know about battery but it's using much more ram then before. Previously free memory was showing 3gb ram but now its only 2.6gb.
    Sahilkum likes this.
  20. JayceJocelyn
    Cupcake Jan 2, 2017
    JayceJocelyn , Jan 2, 2017 :
    Can I just flash the posted zip for oos 4.0 with TRWP? Using oos compatible TWRP...
    Cheers
