591
OxygenOS 4.0 (N) OTA for OnePlus 3
  1. Jxbfs
    Gingerbread Jan 2, 2017
    Jxbfs , Jan 2, 2017 :
    Feature requests for the next upgrade :-
    1. Better camera quality
    2. Adding ability to take extended screenshots
    3. Somehow add Google assistant if possible 4. Resizing app drawer
    5. Editing notes in the shelf!
  2. kmzenon
    Froyo Jan 2, 2017
    kmzenon , Jan 2, 2017 :
    Ur only option is download zip and update it via local upgrade in system update.
  3. G_Brian_Hunt_qITq
    Cupcake Jan 2, 2017
    G_Brian_Hunt_qITq , Jan 2, 2017 :
    I just upgraded to Oxygen OS 4.0 and now have a stuck voicemail notification - I don't have any new voicemails. Is there a way to get rid of this?
  4. Jxbfs
    Yes, problem is solved now thanks anyways.
  5. G_Rupak_dutta_UWry
    Cupcake Jan 2, 2017
    G_Rupak_dutta_UWry , Jan 2, 2017 :
    is this nougat 7.0 update support jio sim..i update nougat last night set to region Canada using opera vpn,but jio sim not working,signal not found...what to do.Is there any sim problem or not
  6. Seifer780
    Seifer780 , Jan 2, 2017 :
    Download OperaVPN, choose eitherCanada or Germany as the region and then go back to System Updates. Once you've verified that it's there, turn off the VPN and download the update.
  7. nyzproof333
    KitKat Jan 2, 2017
    nyzproof333 , Jan 2, 2017 :
    Finally keeping promises! Something I can support! Nice work One Plus.
    SoniaB likes this.
  8. lucifer_angel
    Honeycomb Jan 2, 2017
    lucifer_angel , Jan 2, 2017 :
    Play store bug is really annoying.
    I'm not able to download or update any app unless I activates power saver mode.:eek::eek:
    Weird but annoyingo_O:confused:
  9. kmzenon
    Froyo Jan 2, 2017
    No matter how much they try they can never provide u with Google assistant, and if u need expanded screenshots u will get it in open beta 10 also newer features arrive extremely fast on betas.
  10. xsonic
    Cupcake Jan 2, 2017
    xsonic , Jan 2, 2017 :
    At this point yes. I will try using app backup and restore application and hopefully that works after a factory reset.
  11. kmzenon
    Froyo Jan 2, 2017
    Once Block it's notification which will remove it then re-enable the notification so u can get notifications in future
  12. G_Anindya_Chatterjee_kuR
    Cupcake Jan 2, 2017
    G_Anindya_Chatterjee_kuR , Jan 2, 2017 :
    So, how do i get that update ? by this VPN thing ?
  13. G_Harish_Gupta_mMdw
    Cupcake Jan 2, 2017
  14. kmzenon
    Froyo Jan 2, 2017
    Check if u have set ur jio sim as data Sim as only data Sim is on 4g and jio works only with 4g, also try rebooting phone once.
  15. F_Devraj_Swain_JGht
  16. kmzenon
    Froyo Jan 2, 2017
    U cN also send ur backups on cloud so that it will restore from cloud later.
  17. kmzenon
    Froyo Jan 2, 2017
    Yeah that's the best way currently
  18. rajukk22
    Cupcake Jan 2, 2017
    rajukk22 , Jan 2, 2017 :
    unable to download the apps from playstore. what's the solution for this. please help me out.
  19. Senteznez
    Donut Jan 2, 2017
  20. Jxbfs
    I believe in the OnePlus :)
    Why can't the give expanded screenshots in the stable version :(
