591
OxygenOS 4.0 (N) OTA for OnePlus 3
  1. G_lampros_symigiannis_KJ
    Cupcake Jan 4, 2017
  2. Asumos
    Ice Cream Sandwich Jan 4, 2017
    Asumos , Jan 4, 2017 :
    since you know how to flash TWRP and stock recovery lets go another route then
    download modified TWRP 3.0.2-1.28 available here
    and download the full OxygenOS 4.0 ROM available here
    if you want root SuperSU 2.79 available here
    silverscorp likes this.
  3. Asumos
    no need to turn on anymore, just plug in and open file explorer it will appear (may take a min but will show)
    just tested with my usb and all my files are there
    Auristic and ghostofcain like this.
  4. G_Himanshu_Tanwar_RRWC
    Eclair Jan 4, 2017
  5. kavan1979
    Cupcake Jan 4, 2017
  6. silverscorp
    Eclair Jan 4, 2017
    silverscorp , Jan 4, 2017 :
    I installed root to restore a backup with titanium backup, then after that I removed root with the su app..
    Yes sideload is a solution but what I don't understand is why keeps giving the error, but thanks for the reply.
  7. biomulv
    Honeycomb Jan 4, 2017
    biomulv , Jan 4, 2017 :
    I am on 4.0 . Came from beta 10.
    What is this update? Anyone else getting it / installed?
  8. G_lampros_symigiannis_KJ
    Cupcake Jan 4, 2017
    G_lampros_symigiannis_KJ , Jan 4, 2017 :
    unfortunately it doesn't work ..,
  9. xcrm
    xcrm , Jan 4, 2017 :
    The first of april.
  10. Topper_Gas
    Jelly Bean Jan 4, 2017
    Topper_Gas , Jan 4, 2017 :
    That looks like the last Beta 10 update, are you sure you are on stable Nougat and not somehow installed Beta 9? What's the build date of OS now on your phone?
  11. G_lampros_symigiannis_KJ
    Cupcake Jan 4, 2017
  12. Mehran_Singh_Katoch
    Froyo Jan 4, 2017
  13. Rajeshr15
    Rajeshr15 , Jan 4, 2017 :
    Clear cache.
    Check if any data saver is blocking fb messenger.
    Try clearing the app itself.
  14. silverscorp
    Eclair Jan 4, 2017
    Thanks, can I dirty flash over 3.2.8?
  15. Sahilk0369
    Sahilk0369 , Jan 4, 2017 :
    Just noticed a small issue with the proximity sensor.
    I was on one call for 5 minutes the sensor worked fine and turned off the screen when I put the phone to my ear, after maybe 2 minutes of hanging up the call I got another call and the sensor stopped working on the second call and did not turn off the screen.
    I have faced this bug just once
  16. Asumos
    first time it did not for me either, but after a min i noticed the usb logo at the top left of my phone (on the status bar)
  17. arnab0207
    Cupcake Jan 4, 2017
    Asumos likes this.
  18. Asumos
    sure, it would just be like doing an update from 3.2.8 just clear the cache at the end of flashing and you should be good... however you will be on EXT4 not F2FS.. the F2FS system is much faster then EXT4.. so if you can afford to do a clean flash and format i would advise doing so...
  19. BloodySword
    Cupcake Jan 4, 2017
  20. G_Himanshu_Tanwar_RRWC
    Eclair Jan 4, 2017
