591
OxygenOS 4.0 (N) OTA for OnePlus 3
  1. xcrm
    Ice Cream Sandwich Jan 6, 2017
    xcrm , Jan 6, 2017 :
    Wrong thread.
  2. Minoharu
    Jan 6, 2017
    Minoharu , Jan 6, 2017 :
    Sorry can you guide me to the right one?
    Where I can get help for my problem?
    xcrm likes this.
  3. xcrm
    No, i'm to stupid to help you.
    fxguru77 likes this.
  4. TheSunnyBoy
    Froyo Jan 6, 2017
    TheSunnyBoy , Jan 6, 2017 :
    Try taking a pic of someone's face in daylight and zoom in, you will definitely notice that, skin is smooth as if it has been edited to soften the face !
    miksi likes this.
  5. Deactivated User
    Jan 6, 2017
    Rui Delgado likes this.
  6. Luki2013
    Cupcake Jan 6, 2017
  7. Deactivated User
    Jan 6, 2017
  8. Minoharu
    Jan 6, 2017
    Thank you for kind reply, I'll check it out ^^
  9. ChinChinati
    Jelly Bean Jan 6, 2017
    ChinChinati , Jan 6, 2017 :
    bug 1: recents HW button doesn't work on first touch if you press it just after you press the home button. (confirmed by some other people too)
    bug 2: LED notifications are acting weird, sometimes they work and sometimes they dont. LED for low battery (battery less than 15%) doesnt glow at all.
    all that^ after a factory reset.
  10. d3prof3t
    Cupcake Jan 6, 2017
  11. xcrm
    On the first of april. It is possible to get it earlier, but that costs some more energy. In that case, you have to read some more in this thread!
  12. Kenny_Vleminckx
    Froyo Jan 6, 2017
    Kenny_Vleminckx , Jan 6, 2017 :
    unfortunately, I did both. To no avail...
  13. ritchiedrama
    ritchiedrama , Jan 6, 2017 :
    That is the WORST and most annoying bug
  14. ironass
    Lollipop Jan 6, 2017
    ironass , Jan 6, 2017 :
    If you are getting it after an FDR, then you should try re-downloading the firmware, see post #2, and re-flashing your phone as it is possible that you have had a corrupt update.
    Kenny_Vleminckx and Zh_kilat like this.
  15. mkernbach
    KitKat Jan 7, 2017
    mkernbach , Jan 7, 2017 :
    I'm using the nova launcher, so no problems here.
  16. SAI320
    Gingerbread Jan 7, 2017
    SAI320 , Jan 7, 2017 :
    Google daydream website confirms some Daydream supported smartphones in which MotoZ listed.So SD820 supports Daydream. can we expect for Oneplus3?..
  17. Auristic
    Lollipop Jan 7, 2017
    Auristic , Jan 7, 2017 :
    There's already a thread about Daydream: please find it and post there... NOT HERE!
    xcrm likes this.
  18. kpoyser
    Sahilkum and Auristic like this.
  19. ritchiedrama
    Ice Cream Sandwich Jan 7, 2017
    ritchiedrama , Jan 7, 2017 :
    I don't see how that would fix it.
  20. srlawren
    Honeycomb Jan 7, 2017
    srlawren , Jan 7, 2017 :
    Oh is it a launcher bug? That must be why I'm not seeing it either, as I use Nova Prime also.
    kpoyser likes this.
