6
OxygenOS 4.1.0 [7.1.1] - Battery Thread
  1. Kirakichi
    Jelly Bean Mar 16, 2017
    Kirakichi , Mar 16, 2017 :
    I feelt like i should share with you guys my battery info after updating to 4.1.0
    100% Battery SS
    I will post more at different battery level, post what you think of 4.1.0
    I think this update really is different from other updates, it feels more stable and effort put in.
    Let's discuss at this thread ONLY 4.1 update, so we don't get confused.
    Right now, AccuBattery says "Screen on: 2.7%/h" when it always says +8%/h no matter what.
  2. ghostofcain
    Marshmallow Mar 16, 2017
    ghostofcain , Mar 16, 2017 :
    Come on, the release was only pushed this morning any conclusions on battery life now are ridiculous.
  3. xjotjotx
    Honeycomb Mar 16, 2017
    ghostofcain likes this.
  4. DracoSura
    Ice Cream Sandwich Mar 16, 2017
    Engrbadar and ghostofcain like this.
  5. Kirakichi
    True, at 98% now and says Screen On Time: 2.4%/h
    Anyway, i'll post another screenie when battery hits under 50%.
  6. Kirakichi
    Tell me, does it really need time when the results are already different compared to other updates i received and seen as? this one was totally different.
  7. dinjesk
    KitKat Mar 16, 2017
    dinjesk , Mar 16, 2017 :
    yes, it needs time to settle.
    check in at a couple of days, and see if it's still the same
  8. doc_sharath
    Froyo Mar 16, 2017
    doc_sharath , Mar 16, 2017 :
    only Noobs comment on battery life just after upgrade!!
    stop creating new threads. start using existing threads!
    you ppl are spamming!!
  9. ghostofcain
    Yes it does, android learns to manage the battery based on your particular usage patterns, until it has bedded in you may get wildly different battery life, very good one day bad the next, so draw a conclusion now would be nonsensical.
  10. Kirakichi
    "Noobs"
    how old are you?
  11. Aditya_the_artist
    Cupcake Mar 16, 2017
  12. chirag bhatia
  13. ghostofcain
    No your not, you've just installed the update and need to give it time to settle, if you do have a genuine issue a factory reset will sort it.
    Deactivated User and dinjesk like this.
  14. dinjesk
    KitKat Mar 16, 2017
    the first ones already dropping in :rolleyes:
  15. Transalp
  16. Deactivated User
    Mar 16, 2017
    snjohn likes this.
  17. Kirakichi
    I can see the battery slowly dropping faster, it's now at 8.4%/h with 1h 32min SOT at 84% battery level.
    Same as before, its a bit better than before (i guess) or it's just a placebo.
    Im glad i have at least no battery issues, heat issues, any issues at all and have latest security patch and android version, what more can i wish for?
    Im using one sim card if any of you are curious.
  18. ksourabh93
    Froyo Mar 16, 2017
  19. dinjesk
    KitKat Mar 16, 2017
    quite normal stats. hope it will settle there or get better in some days
  20. F_Peter_Fotopoulos_LvwU
