449
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3
  1. msvr
    Honeycomb Mar 17, 2017
    msvr , Mar 17, 2017 :
    You just made THE LIST OF JERICHO AND THE HORSEMEN, oh wait, you posted it second time.. so you're entry X2...
    You'll get the update eventually.. no matter what the country/regioin..
  2. anandbs155
    Eclair Mar 17, 2017
  3. kishelraj
    Eclair Mar 17, 2017
  4. Rohit_Singh07
    Froyo Mar 17, 2017
  5. RonaldM
    Ice Cream Sandwich Mar 17, 2017
    RonaldM , Mar 17, 2017 :
    I love the update, wifi is more stable and a bug I reported with a public access point is fixed like promised by support. My Fitbit connection (Bluetooth) is more stable.
    Overall experience is stable and fast. I am very satisfied with the update.
    Auristic, Bobbie63, zoran81 and 2 others like this.
  6. zoran81
    Jelly Bean Mar 17, 2017
    zoran81 , Mar 17, 2017 :
    Maybe he was in the toilet
  7. Alpha Mike Foxtrot
    KitKat Mar 17, 2017
    Alpha Mike Foxtrot , Mar 17, 2017 :
    Stop spamming! The update is incremental. It'll get there.
  8. Bubba10
    Gingerbread Mar 17, 2017
    Bubba10 , Mar 17, 2017 :
    It's quite laggy although battery standby has improved. Even the open beta had this lagging so had to revert back to 4.0. Is it just me or anyone else has noticed this lagginess in the new update?
  9. Alpha Mike Foxtrot
    KitKat Mar 17, 2017
  10. xcrm
    xcrm , Mar 17, 2017 :
    2 times the same message in 10 minutes. Use that time to read this thread and you have your answer!
    Bobbie63, zoran81 and msvr like this.
  11. msvr
    la
    laggy, like app opening speed longer than before as somem user reported before or the whole phone i snappy?
  12. dinivaj
    Eclair Mar 17, 2017
    dinivaj , Mar 17, 2017 :
    Very good update. I updated from open beta without problems just cleared the cache.
  13. F_Ahmad_Hamouda_EPpl
    Cupcake Mar 17, 2017
    F_Ahmad_Hamouda_EPpl , Mar 17, 2017 :
    after installing update
    capacitive keys and volume key stop working.
    I tried wipe cash with no result.
    I do not want to use hard reset.
    how can I remove this update?
    or how to solve this issue
  14. aquilla
    aquilla , Mar 17, 2017 :
    Hey,
    my docked icons are since the update smaller than the other ones, also the luncher has no 5 instead of 4 columns (no customisation possible in settings, can just change the icon pack).
    Just wonder if it is just a bug in my phone or intended to be like this.
  15. F_Ahmad_Hamouda_EPpl
  16. G_Rory_Farwell_Clpa
    Eclair Mar 17, 2017
    G_Rory_Farwell_Clpa , Mar 17, 2017 :
    to get this update now, download opera vpn, set the region to Canada and you'll see the update when you go to system updates in settings
  17. G_Rory_Farwell_Clpa
    Eclair Mar 17, 2017
  18. Alpha Mike Foxtrot
    KitKat Mar 17, 2017
    For reverting you can download the the full zip for 4.0.3 and sideload it. A hard reset would easily solve this "problem", though.
    xcrm, Bobbie63 and msvr like this.
  19. diptajit.paul
    Froyo Mar 17, 2017
    diptajit.paul , Mar 17, 2017 :
    Download opera vpn app from playstore, connect to canada region and then check for system update, you will find the update.Once you see the updaye available, disconnect the vpn, and then download the update. I did the same way, and it worked.
  20. Alpha Mike Foxtrot
    KitKat Mar 17, 2017
    Change your default language to US English. You should get the update today.
    The update depends on Google and not OP.
    zoran81, xcrm, Bobbie63 and 1 other person like this.
