449
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3
  1. elanglois
    Lollipop Mar 17, 2017
    elanglois , Mar 17, 2017 :
    Open Settings Apps, find Google Now, clear all its storage. Now open it, go to Voice and set up the Voice detection.
  2. lukas391
    Honeycomb Mar 17, 2017
    lukas391 , Mar 17, 2017 :
    You're talking about very simple things. But not reading what I'm writing :D I said that in 4.0.3 I was using this apps for much longer time and phone was still COLD. Now in 4.1 I can use ONLY instagram for example, for about 2mins and phone is HOT. I don't think that this is normal.. :)
  3. elanglois
    That isn't typical. Everyone else says the exact opposite, so its up to you to find the problem
    Auristic likes this.
  4. lukas391
    Not everyone. Yesterday I saw that people has this problem like me.. :)
    Oxygen os is strange... Some people have heating problem in 4.0.3 and some(like me) don't have. And now I have heating problem in 4.1 when other people is happy without heating... :D
  5. Pakly
    Cupcake Mar 17, 2017
    Pakly , Mar 17, 2017 :
    installation failed after reboot. anyone help me please. [e]1f625[/e][e]1f625[/e][e]1f625[/e][e]1f625[/e][e]1f625[/e]
  6. msvr
    msvr , Mar 17, 2017 :
    sry for the misunderstanding part. so like many in this thread would say. try flashing/sideloading the full ROM.. I guess that's the only option left for you right now
  7. lukas391
    I downloaded ~300 MB package, installation was failed and then I had to download ~1.4 GB file. :) I think I have full rom.
  8. SheryVM
    Gingerbread Mar 17, 2017
    SheryVM , Mar 17, 2017 :
    Really.....if so then I am really surprised about OnePlus tagging you about it..
    In OnePlus 3t there is EIS 2.0 so I thought they have implemented that on 3 but when checked the 3t changelog it is similar , wonder how the 3t fares now...
    Anyway, have they atleast improved upon the stabilization in 4k and 1080_60..and also pic quality in motion scenarios..
    really was looking forward to this camera improvement ..
    Thanks for your feedback...
  9. elanglois
    Nope, free one. How long did you run it?
    Check md5 of download
  10. msvr
    @Bobbie63 , If I'm right... Downloading the full rom over the air. And flashing it/sideloading makes a difference right?
    @lukas391 let's wait out..
  11. msvr
    2-3 days..
  12. lukas391
    I did factory reset, I will see if it will work better..
  13. ldbs101
    Eclair Mar 17, 2017
    ldbs101 , Mar 17, 2017 :
    well typing out an essay could of just given the time ,instead of sounding like a tough guy on a forum.
    if you know the answer why not share. sometimes searching doesn't always work
  14. msvr
    Bro cmon he gives most of the solutions here... searching does work.. He never sounded like a touh guy, it's because he himself posted it a couple of times
    ghostofcain likes this.
  15. G_Jason_Ellis_CUHU
  16. zoran81
    Jelly Bean Mar 17, 2017
    zoran81 , Mar 17, 2017 :
    Good as it was before
    ghostofcain and msvr like this.
  17. zoran81
    Google assistant has nothing to do with Oxygen OS.
    If you want it go to settings and change your language to english (US), then go to apps, google play services and clear the cache. You should get it.
    I get it this way.
    Also if you change laguage back, you will lose assistant.
    noquarter and msvr like this.
  18. TicTacTabarnack
  19. dying_osiris
    dying_osiris , Mar 17, 2017 :
    Has anybody noticed that the lag while pulling down the notification tray has gone post update. This is great coz the bug was really annoying.
  20. lukas391
    But now we have other bug with notification tray :D
    msvr likes this.
