449
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3
  1. alexpch79
    Froyo Mar 25, 2017
  2. Android450
    Marshmallow Mar 25, 2017
    Android450 , Mar 25, 2017 :
    They're pretty much the same, it's up to you if you want to stay getting beta updates or not
    xcrm and Bobbie63 like this.
  3. Stanley08
    Gingerbread Mar 25, 2017
    Stanley08 , Mar 25, 2017 :
    Okay, then maybe i will dirty flash Beta 12 first. If that doesn't work too well, then i will clean flash Official 4.1. Sounds good??
  4. Android450
    I'd clean flash the beta anyway if that's what you want to stick with but it's up to you, and yes clean flash if you're going to official OTA
  5. F_Luquetti_Kardi_zphI
    Cupcake Mar 25, 2017
    F_Luquetti_Kardi_zphI , Mar 25, 2017 :
    buenas quiero saber cómo activo La opción de que el oneplus 3t versión Oxygen 4.1.0 nougat 7.1.1 lea los pendrives o conectarle con éxito cables OTG? no encuentro La opciob.espero vuestra ayuda gracias!!!
    in english: traductor Google:
    Good I want to know how active The option that the oneplus 3t version Oxygen 4.1.0 nougat 7.1.1 read the pendrives or successfully connect OTG cables? I do not find the opciob.espero your help thanks !!!
  6. Alpha Mike Foxtrot
    KitKat Mar 25, 2017
    Alpha Mike Foxtrot , Mar 25, 2017 :
    First, this thread is for OP 3.
    Second, OTG is enabled by default for Nougat. If you are not able to see your pen drive, download Solid File explorer from Play Store.
  7. BobbyV8_
    The Showcase Reviewer Mar 25, 2017
    BobbyV8_ , Mar 25, 2017 :
    ZTE & oneplus released it on 16th March, taking the time of release & the spread, OP takes edge.
  8. jatink007
    jatink007 , Mar 25, 2017 :
    Anyone getting drain like this overnight?
    The phone is just awake all the time
    Some help please. I had installed, factory reset cache wipe. wanted for a week for OS to stabilize, and I still see thsi
  9. F_Robin_Bhat_JsqX
    Donut Mar 25, 2017
  10. Raahul Bhaskar
    Raahul Bhaskar , Mar 25, 2017 :
    hi friend. i want to know how to take expanded screenshot.
  11. Android450
    How did you factory reset? Through recovery?
  12. Govardhan_21
    Govardhan_21 , Mar 25, 2017 :
    this ota isn't worth it. the battery has gotten worse. the camera isn't as incremental as expected and minor shakes still produce blurry pictures. the battery doesn't last even for half a day
  13. F_Jerin_Joy_PWji
    F_Jerin_Joy_PWji , Mar 25, 2017 :
    Please make the front camera eligible for group selfie... While taking the group selfie, phone holding person is more perfect and the others are blured
  14. jatink007
    yes, didn't wipe data, just a factory reset
  15. jatink007
    it works just fine. are you having the correct sim as default data sim?
  16. Stormbreaker_Cj
    Eclair Mar 25, 2017
  17. Android450
    Wipe through recovery it's more effective and should help
  18. ironass
    Lollipop Mar 25, 2017
    ironass , Mar 25, 2017 :
    See post #3649
  19. divyesh. sahu
  20. pavanraghavaraju
    pavanraghavaraju , Mar 25, 2017 :
    My phone is getting very hot while playing games after the Oxygen OS 4.1.0 (7.1.1) OTA update. front cam produces mirror image issue is still not fixed from the beginning.
