449
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3
  1. Fox Mulder
    Eclair Mar 27, 2017
  2. Fox Mulder
    Eclair Mar 27, 2017
    Fox Mulder , Mar 27, 2017 :
    Same here
  3. Deactivated User
    Mar 27, 2017
    ghostofcain and xcrm like this.
  4. zoran81
    Jelly Bean Mar 27, 2017
    zoran81 , Mar 27, 2017 :
    Suggestion for both of you.
    Read the damn thread. Or at least do some searching. Here or on google.com.
  5. zoran81
    xcrm likes this.
  6. G_Joydip_Dutta_LgMb
    Cupcake Mar 27, 2017
    G_Joydip_Dutta_LgMb , Mar 27, 2017 :
    What do you mean? I don't understand. You think my English is bad.
  7. chazey2
    chazey2 , Mar 27, 2017 :
    You sound like an experienced user so try something drastic. I have in the past when flashing ROMs on this and other devices completely wiped every area of the phone save recovery so there is absolutely nothing of anything left behind then installed from either ext card,usb or ADB.
    This will ultimately show one way or another the hardware or software.
    I do realise this action should not be nessesary for any user but it may be fragments not getting cleared in standard flashing.
    Edit meant to quote deannotdin
  8. tedulus
    Honeycomb Mar 27, 2017
    tedulus , Mar 27, 2017 :
    Nobody else but me has the problem with Facebook Messenger that gets killed in the background ?
  9. F_Fabian_Suzański_djdQ
  10. Deactivated User
    Mar 27, 2017
    xcrm likes this.
  11. deannotdin
    Donut Mar 27, 2017
    deannotdin , Mar 27, 2017 :
    Quicktip: You can quote me by editing :tonguewink:
    I chose not to flash any 4.1.0 OOS to my device because it was only uploaded by 3rd party (users uploading the file to their GDrive), and I do not trust them.
    So while I wait for OnePlus to supply the public with the official zip for this version, I chose to downgrade back to the last release until OnePlus will acknowledge the issue and resolve it. I can't stay with a phone that drains and powers off after 40 minutes.
    Just to supply some more information with my issue, and because I hadn't supplied any screenshots in this thread, here are some screenshots of my battery stats (from right now, after 3 days with this ROM after a factory reset) to show that the issue is without doubt defected android components for you and @Bobbie63:
  12. Kasperskau
  13. fireboy3x
    Eclair Mar 27, 2017
  14. ironass
    Lollipop Mar 27, 2017
    ironass , Mar 27, 2017 :
    xcrm likes this.
  15. fireboy3x
    Eclair Mar 27, 2017
    fireboy3x , Mar 27, 2017 :
    is your phone in English? try it by changing your language to English
  16. jatink007
    Gingerbread Mar 27, 2017
    jatink007 , Mar 27, 2017 :
    I have been searching for something similar to wakelock detector since Android 5.0, nothing works without root
    prashanth2692 likes this.
  17. zoran81
    You have few options:
    - read the thread to find the solution,
    - search the forum to find the solution,
    - search the google to find the solution,
    - wait.
    Choose wisely.
    xcrm and ironass like this.
  18. lkosova
    Ice Cream Sandwich Mar 27, 2017
    lkosova , Mar 27, 2017 :
    I just enabled it yesterday by holding down the home button and it asked to let me have Google use my location.... Honestly, not that impressed and not an advantage over Google now.
    Bobbie63 likes this.
  19. ironass
    My weapon of choice for some years now has been BetterBatteryStats for detecting what is using my battery and causing wakelocks and partial wakelocks. It is the big boys toy and can be used on some unrooted devices by using the instructions on their website, here.
    jatink007 and Bobbie63 like this.
  20. chazey2
    From your screens yes it's horrendous. I'm using full zip from XDA. What have you got to loose trying the full zips. If it's no good then do the down grade as you plan.
    Stats so bad it must be worth at least a try on the full zip. But of course your device your rules.
    And this time remembered the quote button!
