449
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3
  1. ekendra
    Eclair Mar 17, 2017
  2. G_Sanchit_Bhatnagar_dSYB
    Gingerbread Mar 17, 2017
    G_Sanchit_Bhatnagar_dSYB , Mar 17, 2017 :
    There's a bug idk if it's due to OOS 4.1 or incompatibility of es Explorer with Android 7.1.1 but I can't no longer use files directly from home screen that I added to desktop via ES File Explorer.
  3. navinf
    Eclair Mar 17, 2017
  4. kowshikpsg
    Froyo Mar 17, 2017
    kowshikpsg , Mar 17, 2017 :
    after updated to 4.1.0 oxygen os 3.54gb memory is pre occupied in others folder I can't able to clear the space even I tried factory reset also any suggestions
  5. balaji93
    Eclair Mar 17, 2017
    balaji93 , Mar 17, 2017 :
    OnePlus 3/3t will reach the same fate, don't worry.... then use the same dialogue
  6. Gaurav Lonkar
    Froyo Mar 17, 2017
  7. aky9788
    Froyo Mar 17, 2017
  8. Dinerve
    Mar 17, 2017
    Dinerve , Mar 17, 2017 :
    Dirty flashed over previous 7.1.1 beta.
    All buttery smooth, can't really tell if there is a difference, looks and feels the same.
  9. G_Kouadio_PHIENY_Michel_
    G_Kouadio_PHIENY_Michel_ , Mar 17, 2017 :
    Roaming is just sh#t not OK with Google, please use WiFi and deal with it
  10. aman3773
    Cupcake Mar 17, 2017
  11. G_Kouadio_PHIENY_Michel_
  12. G_Mohammed_Najmuddin_EpV
  13. G_Mayur_Kale_IDgo
    G_Mayur_Kale_IDgo , Mar 17, 2017 :
    why Same question always be there when new OTA updates are available? there is a clear instruction that this is incremental update will hit the device step by step. so please be pensions guys. mean while you may get the same from other location server.
  14. G_Kouadio_PHIENY_Michel_
    Are you kidding with me.? It's not true install. Daydream from apk mirrors all. is ok
  15. Tamzidul
    Tamzidul , Mar 17, 2017 :
    Thanks for the update. However im not liking the bengali font that is used to show up bengali texts in this version. Can anyone suggest how can i change this?
  16. yuezhouh
    Eclair Mar 17, 2017
    yuezhouh , Mar 17, 2017 :
    Was "disable IpV6" option in the WiFi menu removed? Without it, there's a significant delay when loading anything while my phone's connected to my provider-provided router.
  17. jayace
    jayace , Mar 17, 2017 :
    My download has reached a 100% but is stuck there and won't give my any options to install. Never happened to me before. Where do I find the file so I can delete it and try again?
  18. delhcf
    delhcf , Mar 17, 2017 :
    worked with opera for me with Germany
  19. antzzz
    Eclair Mar 17, 2017
  20. delhcf
    shows up with Opera VPN
