275
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3T
  1. F_Tom_Stewart_Mgmx Donut Mar 20, 2017
  2. rajfrnds Cupcake Mar 20, 2017
    rajfrnds, Mar 20, 2017 :
    Looks like hotspot issue hasnt been fixed in this update also,Hotspot still gets disconnected every 15 minutes on usage and again we need to enable it :( feel bad that OP team aren't taking this bug seriously.
  3. Lonesome Barbarian Gingerbread Mar 20, 2017
  4. MimmoScogna Eclair Mar 20, 2017
    MimmoScogna, Mar 20, 2017 :
    Se hai la beta riceverai solamente gli update della versione beta. Per passare alla versione "stable" devi flesharla a mano, trovi tutto spiegato nel primo post del thread dedicato alla beta
  5. G_Ashwini_Godara_JHQf Cupcake Mar 20, 2017
  6. Master_TC Jelly Bean Mar 20, 2017
  7. uday mishal Cupcake Mar 20, 2017
  8. staufen Gingerbread Mar 20, 2017
    staufen, Mar 20, 2017 :
    saresti così gentile a spiegarmi meglio nn sono un granché esperto.
    credevo che dalla versione beta avrei ricevuto in ota la versione stabile ma sembra che così non è
    devo quindi aspettare che pubblichino il download e fleschiare manualmente?
    grazie
  9. xxocu Marshmallow Mar 20, 2017
    xxocu, Mar 20, 2017 :
    Devi aspettare qualche giorno. Se non hai pazienza scaricati opera VPN scegli Canada ricerca aggiornamento e vedrai che lo trovi.
    staufen likes this.
  10. xxocu Marshmallow Mar 20, 2017
    :p:p:p:p:p:p
  11. G_Yohan_Pavri_AMws Donut Mar 20, 2017
    G_Yohan_Pavri_AMws, Mar 20, 2017 :
    Bro plz don't duplicate questions we're forming a bad impression of ourselves out here. Download Opera VPN and set ur location to Germany or Canada and you'll get the update immediately. Also try and reply to maximum Indians so we don't end up spamming the forums further.
  12. mlmason75 Cupcake Mar 20, 2017
    mlmason75, Mar 20, 2017 :
    I did not update yet but what is with all the reports that AM/PM no longer showing in the status bar?
    I hope that will be fixed quickly!
    Also other then the AM/PM missing what are the other known bugs or issues in OxygenOS 4.1.0 7.1.1 update?
  13. terriixx Donut Mar 20, 2017
    terriixx, Mar 20, 2017 :
    I changed my vpn to Germany so I could install this update.
    And then I've changed my language to English (US) but I still haven't got the assistant on my OP3T
  14. Ati_ansari Cupcake Mar 20, 2017
  15. Stow Gingerbread Mar 20, 2017
  16. Akhil_Parujan Gingerbread Mar 20, 2017
    Akhil_Parujan, Mar 20, 2017 :
    I don't believe the OTA for India is out yet. The OTA for India is a bit different because it comes with different app pre-loaded.
    No, I don't believe so. Hoenstly the update only brings one new feature called Extended Screenshots, unless you really need the wireless radio fixes then you could use a VPN to Canada or Germany to get 4.1.0.
    Otherwise I would wait.
    Dhiren Velari likes this.
  17. G_Marco_Cardoso_bagd Cupcake Mar 20, 2017
  18. tedcohen Cupcake Mar 20, 2017
    tedcohen, Mar 20, 2017 :
    ___________
    Hi,
    Why is this update not available to download from OP's webpage?
  19. G_Vivek_Notty_NrbU Froyo Mar 20, 2017
  20. F_Ibran_Ali_gHYT Cupcake Mar 20, 2017
