225
OxygenOS 4.1.1 (7.1.1) OTA for OnePlus 3
  1. Android450
    Marshmallow Apr 13, 2017
    Android450 , Apr 13, 2017 :
    Uninstall updates from play services and update it again then reboot
    xcrm, Bobbie63 and cmitchellshaw like this.
  2. abechung
    Ice Cream Sandwich Apr 13, 2017
    abechung , Apr 13, 2017 :
    Has anyone in USA gotten the update without VPN? Last time I VPNed the update to 4.1.0, i had to wipe data and cache to restore. Not trynna do that again.
  3. Android450
    The VPN couldn't have caused the issue that you had, it's impossible for it to do so. If you had downloaded the update natively I can guarantee you would have had the same issue. But no we don't know when you'll get it
    xcrm, ghostofcain and zoran81 like this.
  4. zoran81
    Jelly Bean Apr 13, 2017
    zoran81 , Apr 13, 2017 :
    As I know nobody got it without VPN.
    Also it i recommended to wipe cache from recovery after every update.
  5. msvr
    Honeycomb Apr 13, 2017
    msvr , Apr 13, 2017 :
    Don't wanna sound noobish, but still. I've lost my patience and did a clean flash by downloading the ROM given in the links here, by 1st wipecache, delete everything, reset system, then Flash 4.1.1, then wipe cache..
    I searched for the issue like any other might have reported and i don't seems to find one..
    The thing is I'm facing Touch latency, not like other users who saying for milliseconds, but this is for real. I click the menu button, it takes at least a second to go to menu, the same goes for almost all clicks,, the latency is is around 1sec... I guess right now I'm facing this issue only when accessing OnePlus Launcher contents.. Does anybody facing the same.. if yes and the solution's already been given except for wipe cache please do reply me just yes, i'll skim through the thread again find the solution.
  6. abhay757
    Cupcake Apr 13, 2017
  7. Android450
    I haven't seen this but maybe try installing the new launcher and see how it works
  8. Android450
    Assistant is only available in a few regions if you want it change your system language to English US
    xcrm and Bobbie63 like this.
  9. Shubham.Verma11
    Froyo Apr 13, 2017
    Shubham.Verma11 , Apr 13, 2017 :
    dude I updated it today.
  10. Bobbie63
    Bobbie63 , Apr 13, 2017 :
    Have you tried to wipe the cache of the OnePlus launcher app?
    xcrm, Android450 and cmitchellshaw like this.
  11. msvr
    I
    guess I don't see much of a difference Bro. :( still a noticeable latency when clicking icons and the time to open.. any other solution?
  12. Android450
    I really can't think of much else, maybe go into developer settings and set the animation time to .5
    xcrm, zoran81 and Bobbie63 like this.
  13. msvr
    I did a clean flash bro... after that only i'm facing the issue.. but still should proceed with wipe caching oneplus launcher app?
  14. msvr
    or should I flash the OS again ? :(
  15. Android450
    Try what I suggested and see if that makes it better
  16. Starkeks
  17. Bobbie63
    You could try.
  18. ghostofcain
    ghostofcain , Apr 13, 2017 :
    Well having read the thread you know what to do.
  19. Android450
    msvr likes this.
  20. msvr
    I guess that might do good! but sry for sounding noobish again. but no one is facing this issue and i'm the only, what might have gone wrong with my phonee.. does it have something to do with the flashing that I did?.?
