348
OxygenOS 4.1.3 (7.1.1) OTA for OnePlus 3
  1. freiord Froyo May 16, 2017
  2. Smilirulz Gingerbread May 16, 2017
    Smilirulz, May 16, 2017 :
    It depends. I`m using it since its release and had no battery draining issues or something. Usually, I get over 20 hours of usage every day( i`m not playing games or stuff like that, just regular apps like social ones or music deezer/soundcloud/youtube ). This is more than perfect for me. I only encountered some minor bugs, but I can live with them. Give it a try.
    Keep in mind that after the update, you`ll have to fully charge your phone 2-3 times. It takes like 3 days until all apps are making their cache files on the phone and in these 3 days you may notice some battery draining. After that, everything should be normal
    Damian_Larkin likes this.
  3. Sridhar Ananthanarayanan Lollipop May 16, 2017
    Sridhar Ananthanarayanan, May 16, 2017 :
    OOS 4.1.3 (Nougat 7.1.1) is super cool. here is my advise:
    backup all your files.
    factory reset
    wipe cache partition from recovery
    reboot
    update
    reboot to recovery
    reboot
    reinstall all your apps and copy back all your files.
    bit of a work. but given so many problems people are reporting, it would be worth doing it to save yourself all the trouble.
    kobleznbitz likes this.
  4. San_baliga Eclair May 16, 2017
    San_baliga, May 16, 2017 :
    no problems whatsoever... it's smooth and found my battery perform better. so would recommend go ahead
    zoran81 likes this.
  5. norilb Gingerbread May 16, 2017
    norilb, May 16, 2017 :
    Some reports show that a lit of the recent updates are actually very dangerous because it is easy for people to hack into any OnePlus phone due to the way that we receive the updates as it is not through a secure line.
  6. mr_priyanshu Ice Cream Sandwich May 16, 2017
  7. PTuT Ice Cream Sandwich May 16, 2017
    PTuT, May 16, 2017 :
    I thought they did update to secure update check. But only if you are using public network, right?
  8. zoran81 Jelly Bean May 16, 2017
    zoran81, May 16, 2017 :
    Yes
  9. smk513 Cupcake May 16, 2017
  10. lkosova Ice Cream Sandwich May 17, 2017
    lkosova, May 17, 2017 :
    So did OP just join 3/3t under one heading or Am I losing it?!!!!
    This should make things less confusing :confused:.....
    Guess their getting ready for the OP 5 threads to start?
    Bobbie63 and Sun90 like this.
  11. Thaher44 Donut May 17, 2017
  12. F_Manish_Krishnamurthy_I Cupcake May 17, 2017
  13. Sun90 Lollipop May 17, 2017
    Sun90, May 17, 2017 :
    Go to XDA forum and you can find one there.
    adpro, xcrm, Bobbie63 and 1 other person like this.
  14. ghostofcain Lollipop May 17, 2017
    ghostofcain, May 17, 2017 :
    Try the OP3T rom, I don't think your going to get this on to install whatever you do.
    xcrm and Bobbie63 like this.
  15. 9790830263 Cupcake May 17, 2017
  16. ghostofcain Lollipop May 17, 2017
    Well OnePlus have a different idea and it's their build.
    Bobbie63, xcrm and Sun90 like this.
  17. kushal.dhar Donut May 17, 2017
  18. ghostofcain Lollipop May 17, 2017
    It was released 13th April.
  19. Bobbie63 Lollipop May 17, 2017
    Bobbie63, May 17, 2017 :
    Why is it, my guts say the flushing system of the box won't be able to handle the amount of **** we are about to face upon the next stable build?
    adpro, zoran81, Sun90 and 3 others like this.
  20. G_nadeem_mughal_hokx Cupcake May 17, 2017
