349
OxygenOS 4.1.3 (7.1.1) OTA for OnePlus 3
  1. Sadra_Imam
    Gingerbread Apr 14, 2017
  2. Austin Crowley
    Cupcake Apr 14, 2017
    Austin Crowley , Apr 14, 2017 :
    ya i got 3t. can change to other thread. no network reset didn't work
  3. _DEDSEC_
    Jelly Bean Apr 14, 2017
  4. Bobbie63
    Marshmallow Apr 14, 2017
    Bobbie63 , Apr 14, 2017 :
    You've earned yourself another 4 jam doughnuts. :):p
    zoran81, xcrm, ghostofcain and 2 others like this.
  5. G_Cliff_Lee_rxkH
    G_Cliff_Lee_rxkH , Apr 14, 2017 :
    Well this version seems a bit choppy. The version I have is the 4.1.3 version but do u know how to change it back to 7.0 I think I would rather wait until I get it over the air...
  6. kaghedo
  7. Dresa91
    User of the Year 2016 Apr 14, 2017
    xcrm likes this.
  8. SimonRam
    Lollipop Apr 14, 2017
    SimonRam , Apr 14, 2017 :
    Maybe get a case?
    zoran81 and xcrm like this.
  9. Sadra_Imam
  10. Sparshgarg174
    Donut Apr 14, 2017
    Sparshgarg174 , Apr 14, 2017 :
    to be more specific, its after the 4.1.3 update which i did yesterday. there are separate threads regarding only similar complaints of this not so optimized update and no fix. Though u did no good but still thanks for replying.
    elkhan likes this.
  11. varma246
    cmitchellshaw likes this.
  12. SimonRam
    A steering wheel in my trousers does that for me.
    (Drives "me" nuts.......Get it:))
    tedulus, xcrm, Spinosaurus and 3 others like this.
  13. Rikunj
    Froyo Apr 14, 2017
    Sparshgarg174 likes this.
  14. Sparshgarg174
    Donut Apr 14, 2017
    it just shows android system consuming the max part of battery after update.. wiping cache didn't work, gonna try wiping data next.. thanks mate.
  15. Sadra_Imam
    Sadra_Imam , Apr 14, 2017 :
    no issue so far here. also i see improvement on battery usage.
    you may want to do a "FULL" charge (not 100%) and then wipe your cache in recovery. hope it will help.
  16. Deepjyotiroy
    Honeycomb Apr 14, 2017
    Deepjyotiroy , Apr 14, 2017 :
    you mean you want to downgrade your Android from 7.1.1 to 7.0? well i don't know how to do that. the mods can help.
  17. ghostofcain
    ghostofcain , Apr 14, 2017 :
    Try flashing the update for OP3T instead, I'm surprised you managed to get THIS update running at all.
    xcrm, ironass and Bobbie63 like this.
  18. Bobbie63
    Miracles still happen you know? :D
    xcrm, ghostofcain and ironass like this.
  19. elkhan
    elkhan , Apr 14, 2017 :
    There is a trouble with proximity sensor - it does not go off while talking over phone, did wipe cache after update. problem still exists
  20. elkhan
