199
OxygenOS 4.1.3 (7.1.1) OTA for OnePlus 3T
  1. moshikor6 Eclair Apr 20, 2017
    moshikor6, Apr 20, 2017 :
    Facing some bt issues on my car. Sound is not working during call. People can hear me but i can't hear them.
  2. kpoyser Honeycomb Apr 20, 2017
    kpoyser, Apr 20, 2017 :
    it's important to clear your cache after each update. Battery drain is hardly a fault of the OS, it's usually some app like Facebook or Skype that's keeping the phone awake, preventing hibernation and constantly refreshing and pulling background data
    rp2pilot likes this.
  3. dserodio Donut Apr 20, 2017
    dserodio, Apr 20, 2017 :
    I hope they release a version with April 2017 Security Updates soon…
    The most severe of these issues is a Critical security vulnerability that could enable remote code execution on an affected device through multiple methods such as email, web browsing, and MMS when processing media files.​
    Note that "Partners were notified of the issues described in the bulletin on March 06, 2017 or earlier"
  4. princembd Cupcake Apr 20, 2017
    princembd, Apr 20, 2017 :
    VOLTE is missing after upgrade. Not able to use Jio anymore to make calls. please help
  5. Swapnadip_Chakraborty Cupcake Apr 20, 2017
    Swapnadip_Chakraborty, Apr 20, 2017 :
    diskUsage fails too in showing about others folder. i tried it already. even tried deleting cache through recovery mode but nothing happened.
  6. onealvideo Eclair Apr 20, 2017
    onealvideo, Apr 20, 2017 :
    Same here. Brand New phone. Took out of box and upgraded to latest update last night. 6-8 Gigs are in no man's land.
    Would like to get that back even though I have the 128 gig model.
  7. kossa Froyo Apr 20, 2017
    kossa, Apr 20, 2017 :
    Two solutions:
    1. stop checking battery stats every 10 minutes, obsession not healthy
    2. stop duplicate threads, there is like billion similar use search option
    #crapthread
    dserodio, otto2 and peaky blinders like this.
  8. peaky blinders Jelly Bean Apr 20, 2017
  9. kossa Froyo Apr 20, 2017
    this is actually great idea !! and remove battery stats on next release!!!
    peaky blinders likes this.
  10. Arbingr8 Honeycomb Apr 20, 2017
    Arbingr8, Apr 20, 2017 :
    I am also facing the same problem. Battery backup was good before...
  11. peaky blinders Jelly Bean Apr 20, 2017
    peaky blinders, Apr 20, 2017 :
    It sounds daft but it isn't. Users won't end up getting paranoid about battery usage and just charge when they need to.
    kossa likes this.
  12. vikrambansal04 Cupcake Apr 20, 2017
    vikrambansal04, Apr 20, 2017 :
    Hello guys,
    I got an update of Oxygen open 5 and after I updated, my home screen and Recents buttons are not working. Mobile data is not working and also Notification Bar is also not working. Please anybody help guys.. Tried hard to solve this but unable to help it..
  13. peaky blinders Jelly Bean Apr 20, 2017
    Nooooooo if it's a new update give it chance to settle down.
    My battery is great using doze in development options and aggressive doze plus greenify from play store
  14. peaky blinders Jelly Bean Apr 20, 2017
    Try going into recovery and clear the cache first. If you got the update via OTA (over the air) then try downloading beta 5 and install either local update or through recovery
  15. Arbingr8 Honeycomb Apr 20, 2017
    I don't know it was fine till the last update. After this 4.1.3 update. Battery discharging very fast. I have already cleared my caches. Still it last for 24 hours with below normal usage.
  16. kossa Froyo Apr 20, 2017
    Did you just randomly picked this thread to post something, or it was on purpose?
  17. peaky blinders Jelly Bean Apr 20, 2017
    Please make sure doze is on in development options
    Try aggressive doze. Works for some but not others or you have the option to optimise apps to save battery.
    I love the greenify app it helps a lot
  18. Arbingr8 Honeycomb Apr 20, 2017
    Yes this might work for u... I m not using greenify app. I have enabled doze mode in developer option. Let's see what happen in the next update or i will go back to 7.0.0
  19. lucier Cupcake Apr 20, 2017
    lucier, Apr 20, 2017 :
    Hi!
    Same issue than the most of you. My battery is draining so fast and the phone heating up in my pocket. I wipe the cache, empty and recharge it several time, same than after the update.
    Next step, a factory reset...
  20. JuanCalvo Eclair Apr 20, 2017
    JuanCalvo, Apr 20, 2017 :
    My phone heated up and it's battery drained fast. Couldn't do calls. Fed up, and reset it from settings (saving the internal storage (pictures, videos, files,...) but not the apps. Works flawlessly now.
