110
OxygenOS 4.1.4 (7.1.1) Hotfix OTA for OnePlus 3 and 3T
  1. PAVAN BP
    Honeycomb Jun 6, 2017
    PAVAN BP , Jun 6, 2017 :
    Or try reloading the full oos file available in downloads section
    Via adb side load or load it to internal storage
    Sun90 likes this.
  2. USandeepReddy
    Cupcake Jun 6, 2017
    USandeepReddy , Jun 6, 2017 :
    I have updated my OnePlus 3 to 4.1.4 & below are the issues that I'm facing
    1. Fingerprint scanner does not work some times. I get the haptic feedback but it does not unlock the screen. The screen does not wake up at all. The power button also does not wake the screen.
    2. Hotspot does turn itself off all by its own.
    3. WiFi gets turned on by turning off the hotspot.
    Please work on these issues & release an update with these bug fixes.
    Thank you,
    Sandeep.
  3. G_Ajaz_Qureshi_UkjS
    Cupcake Jun 6, 2017
    G_Ajaz_Qureshi_UkjS , Jun 6, 2017 :
    Hi there, I don't know whether this is the right thread or not but still....since I got updated to Oxygen OS 4.1.4 I'm facing battery drain issue - using 4G or WiFi drains 1% of battery with every 5 minutes of usage. My emails aren't synching, keeps saying login issue and starts synching emails from 3rd of Jan 2017 again and again. The phone heats up with usage of 5-10 minutes.
  4. Bobbie63
    Marshmallow Jun 6, 2017
    Bobbie63 , Jun 6, 2017 :
    First I would try is clear cache in recovery. Shouldn't that work, you could try to run the device in safe mode for a while to see if the problems still occur. Running in safe mode rules out any 3rd party apps, which might cause issues.
    adpro, PAVAN BP and Sun90 like this.
  5. Sargos
    Froyo Jun 6, 2017
  6. PAVAN BP
    Yep...u know what, a great man once said "Be happy with what you have" -to be like that the method is changing the mindset
    Another option___________
    Bobbie63 likes this.
  7. Bobbie63
    PAVAN BP, adpro and Sun90 like this.
  8. PAVAN BP
  9. Srinivas_3T
    Froyo Jun 6, 2017
    Srinivas_3T , Jun 6, 2017 :
    try enabling WiFi option under settings-->Customisation-->status Bar (or)disable/enable WiFi option and see if it working .. I was able to disable and enable few icons as required and it's working without any issue
  10. Mt.Everest
    Froyo Jun 6, 2017
    Mt.Everest , Jun 6, 2017 :
    May modi knows this stuff
    NepalOneplus likes this.
  11. NepalOneplus
    Donut Jun 6, 2017
    NepalOneplus , Jun 6, 2017 :
    India is unique with very hot climate may be
  12. NepalOneplus
    Donut Jun 6, 2017
    he is busy in making India clean and green.
  13. bulletmark
    bulletmark , Jun 6, 2017 :
    Normally after a new update this forum gets smashed with "when are we going to get the update in India" posts. So to release this first and only in India is OnePlus's way to play a joke on us all. :)
    lepathie likes this.
  14. G_Aditya_Talkokul_kFNQ
    Cupcake Jun 7, 2017
  15. mauleethorat
    Eclair Jun 7, 2017
  16. F_Shivankur_Uniyal_Emqp
    Eclair Jun 7, 2017
  17. SJBoss
    Lollipop Jun 7, 2017
    SJBoss , Jun 7, 2017 :
    you are already on Android 7 (4.1.3 is based on 7.1.1)
  18. nit1111
    Cupcake Jun 8, 2017
    nit1111 , Jun 8, 2017 :
    Hi
    I am currently in UAE and facing screen flickering since last update to 4.1.3, now I always have to reboot then delete system properties and setting whenever I get this. Is there any other solution for this.
    Thank You
  19. G_Gabrel_Ve_Vance_cYhp
    Cupcake Jun 29, 2017
    G_Gabrel_Ve_Vance_cYhp , Jun 29, 2017 :
    there is a bug I have been having since this update . occasionally the finger print reader scans and unlocks slowly . the unlock vibration is sound , but it turns a little while to unlock.. any one else having this issue?
  20. Kospalito
    Froyo Jun 23, 2021
