321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Nabil609
    Ice Cream Sandwich Aug 28, 2017
    Deactivated User likes this.
  2. dodojanik
    Honeycomb Aug 28, 2017
  3. donpablos
    Froyo Aug 28, 2017
  4. Arjun_Patel_6878
    Froyo Aug 28, 2017
  5. Inumineq
    Donut Aug 28, 2017
    Inumineq , Aug 28, 2017 :
    Just updated my OP3T yesterday - and now the flashlight is broken. It can't be turned on and the phones does not react to pushing the button. Strange bug.
  6. hugorx
    Eclair Aug 28, 2017
  7. RASTAVIPER
    Jelly Bean Aug 28, 2017
    RASTAVIPER , Aug 28, 2017 :
    Just download manually the update file and flash it.
    The link is at the oneplus firmware page.
  8. Petjitsu
    KitKat Aug 28, 2017
  9. xcrm
    xcrm , Aug 28, 2017 :
    Use search and read.
    Bobbie63 and Deactivated User like this.
  10. xcrm
    Yes, search and read.
  11. xcrm
    No, you are not the only one. The solution is somewhere in this thread. Use the search function.
  12. xcrm
    Which issue? Please use the Reply key.
    ghostofcain and Bobbie63 like this.
  13. derekd84
    Eclair Aug 28, 2017
    derekd84 , Aug 28, 2017 :
    I second this assessment.
    I have been having gps issues with both Google Maps and Waze.
    In both cases I will be driving and either the arrow representing me will be stuck in one place or drifting to nearby locations but not on the road being traveled.
    Sometimes it will sort itself out and begin working while other times I just close the apps and forget it all together because it doesn't work.
    Never had an issue like this before the 4.1.7 update.
    S.Svärd likes this.
  14. Inumineq
    Donut Aug 28, 2017
    Thank you, very appreciated! [e]1f389[/e]
  15. xcrm
    Take your own action. Use search and read for the solution!
  16. Vinit Dedhia
    Froyo Aug 28, 2017
    Vinit Dedhia , Aug 28, 2017 :
    There is a problem of notifications disappearing after 1 minute from the notification panel.. So have to open the app manually... I thought after updating to 4.1.7 this problem won't exist because in earlier OS, this problem was with 1 or 2 apps hardly and now this is happening with all apps, and after the update still the problem not resolved.. Somebody help plz..
  17. animon93
    Froyo Aug 28, 2017
    animon93 , Aug 28, 2017 :
    Sounds like a good advice... 4.1.6 works fine and security patch isn't that of an importance.. rather wait for the next one aka Oreo!! :D
    Sun90 likes this.
  18. Alpinski
    Froyo Aug 28, 2017
    Alpinski , Aug 28, 2017 :
    OK. Day 2 with the new update.
    Phone is still running well and appears to be smoother than on previous build.
    Need more time to comment on the battery life but so far I haven't seen any difference, given my specific usage of the device.
  19. G_TV95_MeLm
    G_TV95_MeLm , Aug 28, 2017 :
    Touch latency issues are almost completely gone. As for battery after 4 days with this build I'm getting 7hrs SOT with 22 hrs phone idle time on average, with 100% charge.
  20. Prudhvi4p
    Eclair Aug 28, 2017
    Prudhvi4p , Aug 28, 2017 :
    Flashlight toggle from the notification bar is not working after updating it to 4.1.7
