321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Deactivated User
    Sep 1, 2017
  2. Alin Skeptik Tudor
    Gingerbread Sep 1, 2017
    Alin Skeptik Tudor , Sep 1, 2017 :
    You guys don't understand the principle of the Android phone...that the cache is needed in your system just so it gets to know your behavior using the device...after a few days of using the phone it will know on what apps should he focus his ram and processor depending on your habits.
    so if you delete the cache that often...he will start creating that cache just to know you again...then again you will have drain.
    So stop deleting the cache that often and you will notice some better battery values and longer On-screen times.
    P.S.:
    TELL OTHERS
  3. RASTAVIPER
    Jelly Bean Sep 1, 2017
    RASTAVIPER , Sep 1, 2017 :
    Give me a few examples of such commands that don't work anymore for you.
    Although I believe that you need internet always for Google assistant to work correctly.
  4. [email protected]+
    Ice Cream Sandwich Sep 1, 2017
    [email protected]+ , Sep 1, 2017 :
    Asking to clear cache only for those do a dirty flash or encounters some unresponsive behaviour from the device just to clear all the dump cache and start as a fresh one, but best solution for those who migrate from beta to stable and vice versa is to have a clean flash with data and cache wipe that most of them do not prefer to get 100% output.
    Alin Skeptik Tudor likes this.
  5. Rajasekaranmam
    Cupcake Sep 1, 2017
    Rajasekaranmam , Sep 1, 2017 :
    Surely it helps other but you do not see helpful, better leave it. No problem to me. If you can then provide more info, instead of pulling others. Understand?!
  6. Petjitsu
    KitKat Sep 1, 2017
    Petjitsu , Sep 1, 2017 :
    and what do you want to do?
    Sun90 likes this.
  7. Sun90
    Starting Point Expert Community Expert Sep 1, 2017
    Sun90 , Sep 1, 2017 :
    You are using the open beta build for now.
    Petjitsu likes this.
  8. Rajasekaranmam
    Cupcake Sep 1, 2017
    Doing factory reset Everytime is a very big pain but thanks, will try it.
  9. Auristic
    Lollipop Sep 1, 2017
    Auristic , Sep 1, 2017 :
    I know where it is but it's hot and damp there: maybe forum pervs would love to but I won't go there...
    Deactivated User and Sun90 like this.
  10. Auristic
    I haven't: and what will be your personal use of that useless feature!?
  11. stigma
    Eclair Sep 1, 2017
    stigma , Sep 1, 2017 :
    WOW, thanks man....for sharing nothing useful.
    What have you seen, how did you test it?
    Arbingr8 likes this.
  12. Arbingr8
    Honeycomb Sep 1, 2017
    Arbingr8 , Sep 1, 2017 :
    I m on it. Have u installed it?
  13. G_Manzoor_Ahmed_xkqv
    Eclair Sep 1, 2017
  14. monugana
    Cupcake Sep 1, 2017
    monugana , Sep 1, 2017 :
    After this update, My oneplus3T is giving very low batter back up, screen time is just 3 hours now.something now right
  15. ssagheer
    ssagheer , Sep 1, 2017 :
    Sarcasm: how hard is it to get it?
    Dresa91, Auristic and Sun90 like this.
  16. Petjitsu
    KitKat Sep 1, 2017
    buy baking powder
  17. monugana
    Cupcake Sep 1, 2017
    After this update, My oneplus3T is giving very low battery back up, screen time is just 3 hours now.something not right
  18. G_Manzoor_Ahmed_xkqv
    Eclair Sep 1, 2017
    G_Manzoor_Ahmed_xkqv , Sep 1, 2017 :
    It's such a shame, everytime I come in this bloody forums everyone is complaining about battery issues in the updates I mean for this darn reason I'm still firmly stuck on Oxygen OS 3.5.3 Android Version 6.0.1. So basically for me until I see better feedback, if it's not broke don't fix it! Thanks to all you guys that I'm not updating ever until I see majority positive feedback!
    Sabbir.Naim likes this.
  19. dcop7
    dcop7 , Sep 1, 2017 :
    I'm asking for more details in order to help people that having problems.
    How posts like this helps?
    - "My battery is bad"
    - "My app stopped working"
    - "My wifi doesn't work"
    - "My phone restarted"
    In order for other to help, this are needed (for battery or other kind of problems):
    - What are the steps to reproduce the issue?
    - What device? OP3 or OP3T
    - Do you have stable or beta?
    - What version do you have? 4.1.7 is the last stable version
    - Did was a clean flash or an update? If it is an update, from what version?
    - Did you wipe cache from recovery?
    - What did you have on (wifi, bluetooth, gps, etc...)? What is the average brightness level?
    - Do you have doze activated? Do you have aggressive doze activated?
    - Can you share a screenshot from the battery stats?
    - Did you wait 2 or 3 battery cicles?
    - Do you have any kernel/mods installed?
    - Did you try a clean flash and wait a few days?
    - Can you share logs?
    - Do you identify any patter to this problem?
    The most detail info for any problems will help to fix this.
    But, first of all, search! Most of the questions was already asked and answered.
  20. F_Andrea_Ippolito_ZsRS
    F_Andrea_Ippolito_ZsRS , Sep 1, 2017 :
    And that's nonsense for me.
    Try for yourself, THEN decide. If you wish you can revert to 6.0, but at least try.
    Many people getting worse battery "after an update" typically have a messed up setup anyway, with battery hungry apps installed, or they messed up something while upgrading.
