321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Alister_ic
    Cupcake Sep 1, 2017
  2. Bartnl
    Lollipop Sep 1, 2017
    Sun90 likes this.
  3. Petjitsu
    KitKat Sep 1, 2017
    xcrm, Bobbie63, Dresa91 and 1 other person like this.
  4. VaibhavBhargava
    Deactivated User, xcrm and Bobbie63 like this.
  5. Bobbie63
    Nougat Sep 1, 2017
    Bobbie63 , Sep 1, 2017 :
    Yes, wasn't it peaceful and quiet? :)
  6. VaibhavBhargava
    varma246, xcrm and Bobbie63 like this.
  7. 7226
    Cupcake Sep 1, 2017
  8. mr_priyanshu
    Jelly Bean Sep 1, 2017
  9. saber1203
    Gingerbread Sep 1, 2017
  10. Jackhass
    Gingerbread Sep 2, 2017
    Jackhass , Sep 2, 2017 :
    This phone is better than ever with this update. I'm getting at least 6h of SOT with 150+ apps installed, without having the feeling to underuse my phone at all.
    This may not sound helpful to you, and I agree it isn't, but after reading tons of whining comments on this forum, I thought it would be fine to leave a positive note here. Cheers from a happy customer.
  11. rohit_sidhu
    Eclair Sep 2, 2017
    rohit_sidhu , Sep 2, 2017 :
    There was a slight technical problem where this thread got merged into the beta, so some posts might have got deleted when restoring this thread.
    Deactivated User likes this.
  12. Deactivated User
    Sep 2, 2017
    Android450 likes this.
  13. AlcaloideDoErgot
    Eclair Sep 2, 2017
    AlcaloideDoErgot , Sep 2, 2017 :
    Battery is better than my previous version 4.0.3, which was the original one that I had when I bought the phone. But... I am having trouble with Google Maps and GPS signal or compass, I don't know, maps is not working as before. The issue with the screen on close to my face continues, sometimes it is off sometimes it is on...
    7226 likes this.
  14. Rajasekaranmam
    Cupcake Sep 2, 2017
    Rajasekaranmam , Sep 2, 2017 :
    Leave it, no issues.
    you know what, both this forum & search options are busted one.
  15. Spelt
    Ice Cream Sandwich Sep 2, 2017
    Spelt , Sep 2, 2017 :
    Factory reset is only necessary if going from like Android M to N or like N to O. Not necessary for smaller updates unless you are having major issues with your phone.
  16. OnePlusOne20
    Eclair Sep 2, 2017
    OnePlusOne20 , Sep 2, 2017 :
    After updating to 4.1.7 , all GPS apps are acting up. takes a while to connect and to get the precise location. keeps losing GPS connection. Am I the only one or it's actually an issue with this update ?
  17. antonis bizos
    Cupcake Sep 2, 2017
  18. SrikanthShenoy
    Honeycomb Sep 2, 2017
  19. Rob.L
    Eclair Sep 2, 2017
    Rob.L , Sep 2, 2017 :
    My OP3T has the same problem, hopefully a fix for it soon, I need it
  20. Ankitbhat12345
    Jelly Bean Sep 2, 2017
