321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. G_Manzoor_Ahmed_xkqv
    Eclair Sep 2, 2017
    Deactivated User likes this.
  2. Deactivated User
    Sep 2, 2017
    Sun90 likes this.
  3. airiartev
    Jelly Bean Sep 2, 2017
    airiartev , Sep 2, 2017 :
    12% of usage from 100 in 4 hours without being used...
  4. Alpinski
    Froyo Sep 2, 2017
    Alpinski , Sep 2, 2017 :
    Alright guys, it's time for me to give you some feedback after 1 week of OOS 4.1.7 :
    1) Sometimes when the screen is off and the device is left untouched for some time, putting my finger on the fingerprint sensor doesn't do anything. It doesn't respond. After you double tap on the display and put your finger back on the sensor it works. This has happened over 10 times in the past few days. I have never had this issue before so I think it is safe to assume that the culprit is the new software update. Yes, I have cleaned the cache a few times in case you will ask. And no, I will not do a factory reset and deal with the hassle of getting my device set up from the ground up. My Sony Z3 had software updates and I never had to clear cache or stuff like that. This is a stupid excuse. Since other manufacturers can do proper updates, so should you. Don't give me that "we're a small company" excuse, because of the fact you are tied and supported by Oppo (the third best selling phone manufacturer in China).
    2)I had one time where the Messenger app was unresponsive, when you click on the bubble it hides and comes on in 2 seconds. Clicking on the app icon doesn't work. After restarting the device things got to normal and I could not reproduce this again since then.
    3) GPS has been showing confusing information in the Google maps app
  5. rohit_sidhu
    Eclair Sep 3, 2017
    rohit_sidhu , Sep 3, 2017 :
    Battery life during moderate use?
  6. Deactivated User
    Sep 3, 2017
  7. AshuEltero
    Froyo Sep 3, 2017
    AshuEltero , Sep 3, 2017 :
    Hey All,
    I'm having some issue on rooting my One plus 3 oxygen 4.1.7.
    I've flashed twrp but when I install SuperSU after that phone stucks on booting.
    Please help on rooting.
  8. Deactivated User
    Sep 3, 2017
    Sun90, xcrm and Auristic like this.
  9. G_Adi_Kusuma_IUdV
    Cupcake Sep 3, 2017
    G_Adi_Kusuma_IUdV , Sep 3, 2017 :
    So much Truee. After the OTA upgrade, i cant use any gps related apps. Please pinned this thread and provide link to Downgrade the OS to 4.1.6. *Desperate*
  10. ashishjena
    Honeycomb Sep 3, 2017
    ashishjena , Sep 3, 2017 :
    And what is "Indian thinking"?
  11. Johnf48
    Cupcake Sep 3, 2017
  12. Arai
    Arai , Sep 3, 2017 :
    Since OP will start the 3/3T end of support count down once Oreo update release, before it comes, could the forum manager start pinning on the popular ROM out there?
    I'm sure the user would like to see what options they have once the hammer drop.
  13. Deactivated User
    Sep 3, 2017
    varma246, Sun90 and Auristic like this.
  14. Deactivated User
    Sep 3, 2017
    7226, varma246, xcrm and 3 others like this.
  15. yumeshram
    Cupcake Sep 3, 2017
    yumeshram , Sep 3, 2017 :
    What battery improvement??? It used to last 1.5 day before. Now it is just a day. Anybody else having this issue?
  16. VaibhavBhargava
    Lollipop Sep 3, 2017
    Sun90 likes this.
  17. rishabhsinghal93
    Cupcake Sep 3, 2017
  18. brunoavellar
    Froyo Sep 3, 2017
    brunoavellar , Sep 3, 2017 :
    Sure. I comes with a handful of useful additions including the touch latency improvements and the latest security patch.
  19. andries.vandenberge
    Cupcake Sep 3, 2017
  20. YehudaGo
    Gingerbread Sep 3, 2017
    YehudaGo , Sep 3, 2017 :
    Yes update, don't bee worry about the battery just after updating clear the cache in settings and it bee mostly fine
