321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. danevans18
    Ice Cream Sandwich Sep 3, 2017
    danevans18 , Sep 3, 2017 :
    I haven't had any issues with 4.1.7 personally.
    I'd say go for it.
    I downloaded over the air
    Installed it
    Booted into recover to clear cache.
    No problems.
  2. noquarter
    Lollipop Sep 3, 2017
    noquarter , Sep 3, 2017 :
    Merged with release thread
    rishabhsinghal93 and Sun90 like this.
  3. SMSaravanan
    Cupcake Sep 3, 2017
    SMSaravanan , Sep 3, 2017 :
    Can u please make apps icons to right and left instead of top to bottom. At least as an option.
  4. VaibhavBhargava
    VaibhavBhargava , Sep 3, 2017 :
    I assume you are talking about the launcher (it will stay that way for the foreseeable future), you should try launchers from play store (they will have that functionality) like Nova, Lawnchair etc.
    Sun90 likes this.
  5. G_juan_antonio_rodrigo_L
    Eclair Sep 3, 2017
    G_juan_antonio_rodrigo_L , Sep 3, 2017 :
    [QUOTE = "danevans17, post: 16737760, member: 1166743"] No he tenido problemas con 4.1.7 personalmente.
    Yo diría que lo hiciera.
    Descargé por el aire
    Instalado
    Iniciado en recuperar para borrar la memoria caché.
    No hay problemas. [/ QUOTE]
    mi problema del bluetooth con los automoviles existe.
  6. Gowri17
    Honeycomb Sep 3, 2017
    Gowri17 , Sep 3, 2017 :
    hi buddy. I m from India. I m also facing ur issue. I bought mobile from abroad. jio sim not working here in India
  7. Gowri17
    volte icon not visible on top even it is enabled. Did I have any idea
  8. VaibhavBhargava
  9. VaibhavBhargava
    Make sure to put the Jio sim as your default data card in 4G mode
    Deactivated User likes this.
  10. Gowri17
    not sure. but my friend gave it to me saying abroad mobile. can I help me regarding this.
  11. iamvshal
    Cupcake Sep 3, 2017
    iamvshal , Sep 3, 2017 :
    After completing 100% download i click on reboot to install.....
    After that download failed message is shown and download starts again
  12. Sun90
    Starting Point Expert Community Expert Sep 3, 2017
    Sun90 , Sep 3, 2017 :
    Go to settings> about phone and check what is under model..
    And post it here
    xcrm and varma246 like this.
  13. VaibhavBhargava
    If it's from china then it won't work there is some issue with the bands in the chinese variant.
    Can you tell me the model - Is it A3010 ?
  14. Gowri17
    in box it represented as a3000.
  15. VaibhavBhargava
    Disconnect your device from the net.
    open file manager and enable "show hidden files" from it's settings
    delete .OTA folder from the internal storage
    reconnect your phone to the net and check for updates
    xcrm and Sun90 like this.
  16. battapothu.venkat
    Cupcake Sep 3, 2017
  17. Sun90
    That's the Chinese variant of oneplus 3.
    Which doesn't support VOLTE in here ,hence Jio will not work.
    Deactivated User, xcrm and varma246 like this.
  18. VaibhavBhargava
  19. VaibhavBhargava
    Wipe app cache from storage settings and wipe system cache from recovery menu
  20. Gowri17
    bro but it shows volte option in it under settings. if I flash the mobile should it enable. because it is volte enabled itself. is there any steps bro.
