320
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. adpro Jelly Bean Sep 12, 2017
    adpro, Sep 12, 2017 :
    You guys are having search party here..huh:oops:
  2. Bobbie63 Lollipop Sep 12, 2017
    Bobbie63, Sep 12, 2017 :
    The order isn't correct I think.
    Hish98, varma246, adpro and 1 other person like this.
  3. Sun90 Lollipop Sep 12, 2017
    Sun90, Sep 12, 2017 :
    Any ideas:p
  4. VaibhavBhargava KitKat Sep 12, 2017
    VaibhavBhargava, Sep 12, 2017 :
    And how big is the disparity in detection of the two locations ? (compare the two of them in google maps)
  5. VaibhavBhargava KitKat Sep 12, 2017
    He forgot the start button !
    Hish98, Dresa91, varma246 and 3 others like this.
  6. Bobbie63 Lollipop Sep 12, 2017
    Last right should be replaced by the first up. Loose the first up and then in front of the first ups left do a down......i think
  7. Sun90 Lollipop Sep 12, 2017
    That's really Confucius.
    deviantartjr, Hish98, Salt505 and 4 others like this.
  8. VaibhavBhargava KitKat Sep 12, 2017
  9. igor.grgurevic Froyo Sep 12, 2017
    igor.grgurevic, Sep 12, 2017 :
    i did it, through sistem settings & and via recovery before but nothing can't stop google play services to drain further
  10. Bobbie63 Lollipop Sep 12, 2017
    Try to delete updates from Google play services (3dot menu), clear cache from play services and finally clear cache in recovery. After reboot, don't update play services manually. See what that does for you.
    adpro, Sun90, igor.grgurevic and 2 others like this.
  11. igor.grgurevic Froyo Sep 12, 2017
    doing it now, we'll see what is going to happen
  12. Bobbie63 Lollipop Sep 12, 2017
    Let's hope for the best. :)
    Should I light a candle?
    adpro, Sun90 and igor.grgurevic like this.
  13. Bobbie63 Lollipop Sep 12, 2017
    Sun90 likes this.
  14. igor.grgurevic Froyo Sep 12, 2017
  15. damirs Donut Sep 13, 2017
    damirs, Sep 13, 2017 :
    hey all,
    Past few days i am losing data connection on my 3t, using this update.
    I need to do 'network setting reset' in order to get data back (working).
    Any1 else having this problem? Any suggestions what to do?
    (I hope factory reset the phone is not the only 'suggestion / solution') :)
    Thank you for your time / help.
    D
  16. Tiwi1990 Ice Cream Sandwich Sep 13, 2017
    Tiwi1990, Sep 13, 2017 :
    i'm having problem with hotspot..i connect my pc but then it says no internet connection
    is there a solution? op3 and 4.1.7 stable
  17. pradhyuman4545 Donut Sep 13, 2017
  18. Dresa91 Nougat Sep 13, 2017
    Dresa91, Sep 13, 2017 :
    It depends what you want
    Sun90 likes this.
  19. Sunnysidharth Cupcake Sep 13, 2017
    Sunnysidharth, Sep 13, 2017 :
    deleteting OTA folder doesn't work...
  20. Sunnysidharth Cupcake Sep 13, 2017
