321
OxygenOS 4.1.7 (7.1.1) OTA for the OnePlus 3 and 3T
  1. VaibhavBhargava
    Lollipop Sep 25, 2017
    Dresa91 and Android450 like this.
  2. Retr_0
    Ice Cream Sandwich Sep 25, 2017
  3. VaibhavBhargava
    Dresa91 likes this.
  4. G_Martin_Myška_CngF
    Donut Sep 29, 2017
    G_Martin_Myška_CngF , Sep 29, 2017 :
    Is possible downgrade from Oxygen 4.5.0 via settings-system updates-gear-local upgrade, when I download full stock rom, without loose of a data?
  5. joshimarx
    Cupcake Jun 21, 2018
    joshimarx , Jun 21, 2018 :
    Hello dear community,
    at the moment im on OxygenOs 3.2.7 and rooted (twrp installed). Can I flash 4.1.7 directly? (dirty flash)
    Thanks!
    Josh:)
  6. leo98918
    Ice Cream Sandwich Jun 22, 2018
    leo98918 , Jun 22, 2018 :
    You can update via OTA, it will unroot your device. Just re-root with Magisk. There are apps that will patch OTAs so you can keep Root, but I haven't had any experience with them, so yeah...
    Here's the app I was talking about:
    https://play.google.com/store/apps/details?id=eu.chainfire.flash
    If you're familiar with Rooting, it won't be a hassle to re-root your device, only takes about 2 mins.
  7. Raviteja4444
    Cupcake Jun 22, 2018
  8. joshimarx
    joshimarx , Jun 22, 2018 :
    But will that work, even if I have 3.2.7 on my OP and also not the latest TWRP version? I'm scared of bricking my phone...
    Josh:)
  9. leo98918
    When you download and install the OTA, your Custom Recovery will be overwritten by the Stock Recovery. Once your phone reboots, you just have to Flash TWRP (preferably the latest version) again and then Root your device with Magisk.
    Your device won't brick but I can't guarantee that 100%, just like when you flash anything, YOU assume ALL risks of what could possibly happen.
  10. joshimarx
    Of course u can't, it's all on my own risk. But thanks so much! Will I loose my data? (Because its not a dirty flash)
    Josh
  11. leo98918
    If you don't wipe data, you shouldn't lose anything, but in all honesty, jumping from 7.X.X to 8.X.X without wiping is just asking for issues. You'll run into to little issues like some quick toggles not working, apps crashing, your device acting funky. It's better to just do it correctly and to have zero issues. Any update afterwards should be fine doing a dirty flash.
    Backup all your stuff and do a clean install.
  12. joshimarx
    Yeah, maybe It's a good idea to wipe... I'll do it like that:
    1. Wipe all data
    2. Root device
    3. install the app you sent me and let it install the new version
    correct?
    Thank you so much for your effort!
    Josh
  13. Bhuvan_G
    Bhuvan_G , Jun 22, 2018 :
    hey guys facing issues with volume issue! volume level gone down after upgrade :( any fix ?
  14. leo98918
    joshimarx
    1. Wipe all data
    2. Root device
    correct?
    Josh​
    You don't need that app I posted, its just something that will allow you to keep Root while installing the OTA. So it's not necessary for a clean install, just future OTAs afterwards.
    1) Backup
    2) Wipe
    3) Install latest OTA
    4) Install TWRP
    5) Root
    6) Backup Clean Install (Optional)
  15. joshimarx
    And you also did it like that? I'm scared it doesnt work because of block-based OTAS since Android 5.0
  16. leo98918
    I do it like that everytime I update from a major OTA (I.E. 7.X.X to 8.X.X). Any minor OTA (X.1.X to X.2.X) I don't do a wipe, I just do a dirty flash and re-root.
  17. dzoni2zr
    Cupcake Oct 8, 2019
    dzoni2zr , Oct 8, 2019 :
    must say one of the best phones i ever used in my life and really top quality by my opinion,but after last update to 9 pie i downgraded to nougat after 7 days my phone was overheating and draining battery in a matter of 4-5hours
    now back on nougat and all fine
