637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Dresa91
    User of the Year 2016 Sep 25, 2017
  2. G_Chris_Pags_(Flyin18T)_
    Froyo Sep 25, 2017
  3. G_Rodrigo_Gomes_TrjG
    Cupcake Sep 25, 2017
    G_Rodrigo_Gomes_TrjG , Sep 25, 2017 :
    Good update now only need to put the new application of camera 2.0 and the new gestures of the system with the screen off, could also let the two screen functions connect the screen with the proximity sensor and also pick up the device
  4. GEBK
    Donut Sep 25, 2017
    vltrua likes this.
  5. dcop7
    Honeycomb Sep 25, 2017
    dcop7 , Sep 25, 2017 :
    So this update doesn't have the new camera? The pro mode like OP5?
  6. Deactivated User
    Sep 25, 2017
    Bobbie63 likes this.
  7. ardakaan
    Gingerbread Sep 25, 2017
    ardakaan , Sep 25, 2017 :
    I have been using OpenBeta for months. However, because of having low SOT values, I switched to OTA. I thought that complete wipe and stable version solve this issue. Yet, it seems that there is not such difference that can be easily seen.
    What do you think? Should I switch to OpenBeta again?
  8. Dresa91
    Dresa91 , Sep 25, 2017 :
    FYI: you get updates as OTA in Beta, too. You meant official OS!
    VaibhavBhargava likes this.
  9. SilverGlove
    Ice Cream Sandwich Sep 25, 2017
    SilverGlove , Sep 25, 2017 :
    That should be your Personal preference i suggest you to stay on the one you are comfortable
    VARUNREDDY95, Bobbie63 and Dresa91 like this.
  10. sechinov
    sechinov , Sep 25, 2017 :
    I think it's like 4.5.2 with an updated security patch at least.
  11. ardakaan
    Yeap. Thank you for correction.
    Dresa91 likes this.
  12. G_Ridwan_Kurniawan_Bdxt
  13. GEBK
    Donut Sep 25, 2017
    GEBK , Sep 25, 2017 :
  14. Anzik
    Anzik , Sep 25, 2017 :
    ROFL, it's a marketing and nothing more
    fricy81 likes this.
  15. dcop7
    Probably the problem is not the ROM. Low SOT is not a good meter for battery. If you have facebook, etc... That drains the battery. Also try to disable aggressive doze, for me it helps. Also, what is low SOT for you? For how long did you disconnect the charger?
  16. Dresa91
    You meant 4.5.11
    There are 4 (?) weeks left for a new update for OP5 - be patient
  17. G_Rajun_Doal_Ieis
  18. Rishvan
    Froyo Sep 25, 2017
  19. mauleethorat
    Eclair Sep 25, 2017
    mauleethorat , Sep 25, 2017 :
    Most awaited update @Jimmy Z. Keep going !!! Cheers !!
  20. Dresa91
    No.
