637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. F_Ashwani_Mishra_bVpM
    Cupcake Sep 25, 2017
  2. nickpetris
    Honeycomb Sep 25, 2017
  3. G_Farid_Soltani_nQiO
    Michelle Tremblay likes this.
  4. Mahammad Ahmed
    Gingerbread Sep 25, 2017
    Mahammad Ahmed , Sep 25, 2017 :
    Will not work..
  5. Xzer
    Froyo Sep 25, 2017
  6. Swadeep mahapatra
    Donut Sep 25, 2017
    Swadeep mahapatra , Sep 25, 2017 :
    turn off but one thing to do man.you just go play store .and search one plus luncher. you can see the app and uninstall update. then you go to show the menu icon.[e]1f44d[/e][e]1f44d[/e]
    sharathchelsea likes this.
  7. shubhampisces16
    shubhampisces16 , Sep 25, 2017 :
    Please provide option to disable floating notifications for individual apps
    It is really annoying to have a whatsapp popup notification
  8. Kevin_2937
    Vinc098 likes this.
  9. shyamprakash007
    shyamprakash007 , Sep 25, 2017 :
    But this is redesigned properly
  10. neerajchachlani
    neerajchachlani , Sep 25, 2017 :
    I tried switching it to Canada and Germany, didn't work, any ideas?
  11. shyamprakash007
  12. shyamprakash007
    Vinc098 likes this.
  13. G_Rajun_Doal_Ieis
    G_Rajun_Doal_Ieis , Sep 25, 2017 :
    after choosing one of the servers go to settings, software update (check for an update), keep updated and I'll keep your OS updated (no pun intended).
  14. neerajchachlani
    did that. it didn't work.
  15. G_Rajun_Doal_Ieis
  16. neerajchachlani
    I'm using Hola Vpn, that's what I used to update to Android 7.0 when it rolled out for Canada
  17. mike499
    Donut Sep 25, 2017
  18. G_Rajun_Doal_Ieis
    Okay, try doing it with Opera VPN and let me know what happens.
  19. Kashish sadh
  20. wilberfan
    Donut Sep 25, 2017
    wilberfan , Sep 25, 2017 :
    I've downloaded the manual patch and put it in my root directory. When I try to apply the update from System Update I get a progress bar up to about 20% when the phone spontaneously reboots into TWRP. Flashing the zip from TWRP gives me a "7" error. Am I doing something incorrectly??
