637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Franck Gélie
    Eclair Sep 25, 2017
    Franck Gélie , Sep 25, 2017 :
    Just disabled the ones you don't you use
  2. Punk_69
    Lollipop Sep 25, 2017
  3. ut2000
    Honeycomb Sep 25, 2017
    ut2000 , Sep 25, 2017 :
    Are you reading the speed off the new speed meter they included in the update? I seems like it doesn't change from "K/s" and I don't think it's even accurate at all. I have the Internet Speed Meter app and compared it with the Oneplus meter and it didn't match. OP didn't even give you the option what speed you want it to be metered in, so I turned it off.
  4. ZeyaTauseef
    Cupcake Sep 26, 2017
    ZeyaTauseef , Sep 26, 2017 :
    OnePlus 5 Camera App 2.0.0 Ported For OnePlus 3/3T was Working Absolutely Fine on OxygenOS 4.1.7 .Now,After OxygenOS 4.5.0 Update It Crashes When We Enable "Shot on OnePlus" Watermark..The Camera App then Only Start When We Clear Data..Without Watermark Enabled,There is No Issue...Pls Tell Me How To Fix This Watermark Crashing Issue...Will You Provide me Latest Stock Camera Apk of OnePlus 5 OxygenOS 4.5.10?
    Sabbir.Naim likes this.
  5. shobuddy
    Donut Sep 26, 2017
  6. Jelsamino
    Sabbir.Naim and dsaputra like this.
  7. jigs_0000
  8. ghostofcain
    Marshmallow Sep 26, 2017
    ghostofcain , Sep 26, 2017 :
    When oneplus have finished rolling it out, there is no definite time frame. If you can't possibly wait try reading the release thread instructions can be found within the first couple of pages.
    BTW within the OP you will find a request not to open redundant threads concerning the release please bear that in mind going forwards.
    Dresa91 likes this.
  9. jigs22061989
    jigs22061989 , Sep 26, 2017 :
    Hi.
    Is OTA now available in every OnePlus 3T models? Because in my mobile no software update showing.
  10. Vidya_Ramesh
    Donut Sep 26, 2017
  11. Bruno Verdú
    Bruno Verdú , Sep 26, 2017 :
    Great update so far. Cannot see though the network speed icon in the notification bar. Is there any way to enable/disable it? Cheers.
  12. G_Richard_Howes_RDKO
    G_Richard_Howes_RDKO , Sep 26, 2017 :
    Did I miss something? Using one operating system on the oneplus 3. Plug in to charge and suddenly the interface is different?
    Not sure if worse or better but definitely unexpected
    chadmrob3 likes this.
  13. Android450
    Android450 , Sep 26, 2017 :
    Yup it's new. Check the pinned threads there's also a new update
    Dresa91 and nobelium76 like this.
  14. Justin709
    Honeycomb Sep 26, 2017
  15. Justin709
    Justin709 , Sep 26, 2017 :
    Settings - Status Bar - Toggle Switch
  16. Ozkan52
    Eclair Sep 26, 2017
    Ozkan52 , Sep 26, 2017 :
    I had to wipe my phone after updating it manually from the beta version of oxygen... In the home screen it always turned black for a couple seconds and then over and over again. Maybe it's my fault maybe not.
    I don't know why but the wifi signal thing is still an issue for me. Maybe it's not even a software problem but the signal is very strange. From 3 out of 4 bars to 1 and then when I'm moving my phone all of a sudden 3 bars again and so on. I never had this issue on a phone before.
  17. Justin709
    You can download the APK for OnePlus music player. Google it.
  18. nitish.raajpal
    Froyo Sep 26, 2017
    nitish.raajpal , Sep 26, 2017 :
    I totally agree, just updated and i am trying to find a way to make it transparent.
  19. p0seidon94
    Gingerbread Sep 26, 2017
    p0seidon94 , Sep 26, 2017 :
    It does. But now the phone won't wake up of you accidentally touch the ambient notification. Something like Samsung's Always ON display.
    fdroko likes this.
  20. MarkAle
    MarkAle , Sep 26, 2017 :
    Not even OnePlus 5 users have that feature, it's beta only and as far I as know it still needs to be ironed. So I guess it'll be added for the Android Oreo updates, which is perfectly fine.
    VaibhavBhargava likes this.
