637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Aswin Philip
    Gingerbread Sep 26, 2017
    Aswin Philip , Sep 26, 2017 :
    I have installed the 4.5.0 update. And chenged the fond to oneplus slate, then moved back to the default roboto font. But the dialer is still showing oneplus slate font.
    Is this font default for dialer now?
    I have cleared cache for dialer too still no change.
  2. pradeep4031
    Eclair Sep 26, 2017
  3. Deactivated User
    Sep 26, 2017
    Aswin Philip and Bobbie63 like this.
  4. vishnugovardhan
    Cupcake Sep 26, 2017
  5. Aswin Philip
    Let me try reboot. Unfortunately, can't afford a factory reset now. :confused:
    ** Screaming it is **:p:D:rolleyes:
    Edit : reeboot didn't work. Will sideload the full zip once its uploaded. Hope that works.
    Bobbie63 and Deactivated User like this.
  6. F_Madhoo_Kanth_EtXF
    Rajesh Kumar C P likes this.
  7. IdrisZari
    Froyo Sep 26, 2017
    Hashirtm likes this.
  8. camohan
    Nougat Moderator Sep 26, 2017
    camohan , Sep 26, 2017 :
    Roll out is in stages. Use VPN if you can't wait.
    Thread merged.
  9. Rafal Jozwiak
    Froyo Sep 26, 2017
    Rafal Jozwiak , Sep 26, 2017 :
    There are some others players you can install:
    MortPlayer, AIMP, BlackPlayer, VLC
  10. Abhishekp93
    Abhishekp93 , Sep 26, 2017 :
    After updating my OnePlus 3 to oxygenOS 4.5.0, i'm not able to reset data used in billing cycle. Is anyone facing the same problem??
  11. raja1506
    Froyo Sep 26, 2017
    raja1506 , Sep 26, 2017 :
    I thought this was a beta one...
  12. amol.zinge
    Donut Sep 26, 2017
  13. G_Chinmay_bapat_oQMj
    Ice Cream Sandwich Sep 26, 2017
  14. F_Mukesh_Lee_BAgE
    Eclair Sep 26, 2017
  15. F_Madhoo_Kanth_EtXF
  16. RawRs
  17. RawRs
    RawRs , Sep 26, 2017 :
    use Opera VPN set to Canada then update OTA !!
  18. nikhil konde
  19. Prashant387
    Prashant387 , Sep 26, 2017 :
    'Do Not Disturb' mode is still not fixed in this update
    when switched to DND mode i hear the ring sound while receiving the call
  20. SanthoshGurram
    Honeycomb Sep 26, 2017
    SanthoshGurram , Sep 26, 2017 :
    You can do
    U can uninstall and update the launcher all. It will be 2.1.5
    peaky blinders likes this.
