637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. F_Thiru_Kumar_SCAQ
    Donut Sep 26, 2017
    F_Thiru_Kumar_SCAQ , Sep 26, 2017 :
    anybody check pattern lock is work fine after this update ?. after update its allowing me to unlock immediately without fingerprint or password
  2. G_Mohammad_Muddasser_Ala
    Cupcake Sep 26, 2017
    G_Mohammad_Muddasser_Ala , Sep 26, 2017 :
    not at all.
    I was using beta.
    then gave this 4.5.0 so called update. and boom.
    apps stopped responding.
    and. yes. did that cache clearing half hour ago.
    even I restarted my op3. but no improvement
  3. smitbhagat
    Honeycomb Sep 26, 2017
    smitbhagat , Sep 26, 2017 :
    Try to click 4-5 pictures continuously by taping the shutter each time,not talkimg abt the burst mode,just tap the button 4-5 times,did the camera app crash?
  4. vinjam61
    Donut Sep 26, 2017
    vinjam61 , Sep 26, 2017 :
    Hi
    I see four icons in the bottom , but in rest of videos it has the 5 apps. is this normal ??
    phone message camera chrome
    How to decrease icon spacing it looks bad
    Display setting g on my phone
  5. G_Mohammad_Muddasser_Ala
    not at all.
    I was using beta.
  6. Dresa91
    User of the Year 2016 Sep 26, 2017
    Dresa91 , Sep 26, 2017 :
    then: clear cache of the app, reinstall those apps, at least do a clean install of OS
    Bobbie63, Pradeep@1+ and tijmen234 like this.
  7. Deactivated User
    Sep 26, 2017
  8. abheshek02
    Gingerbread Sep 26, 2017
    abheshek02 , Sep 26, 2017 :
    I don't know for sure but I think it's part of user interface design. So you cannot do anything about it.
    VishalHDR likes this.
  9. Bigdeath
    Froyo Sep 26, 2017
    Bigdeath , Sep 26, 2017 :
    I do not like the update. Why does it not work anymore that I hold my hand over the Smartphone and the screen goes on? I do not want to have to lift it up.
  10. Deactivated User
    Sep 26, 2017
    Dresa91 likes this.
  11. Pradeep@1+
    Ice Cream Sandwich Sep 26, 2017
  12. dhanraj_kumar
    Eclair Sep 26, 2017
  13. Bigdeath
    Froyo Sep 26, 2017
    I want the old feature to hold my hand over screen. Not special lift up. You understand?
    Abhi Dahiya and Chrischn_D like this.
  14. G_Thomas_S_PyvV
    G_Thomas_S_PyvV , Sep 26, 2017 :
    The OP5 has new gestures on screen off (the S and the W), which can be assigned to any app. We only have O and V and we can't assign them to other functions/apps
  15. Pradeep@1+
    Pradeep@1+ , Sep 26, 2017 :
    I strongly recommend full factory reset, ie, both cache and data wipe, while coming from beta to stable, but just need cache wipe when going from stable to beta
  16. bjrg
    bjrg , Sep 26, 2017 :
    Nice update...Added some essential features like speed indicator and re-designed phone UI
    But one thing that bugs me is the font thing...
    Couldn't find any difference between slate and roboto or is there any?
  17. vybramo
    Donut Sep 26, 2017
    vybramo , Sep 26, 2017 :
    That collors .... OVERSATURATED !!!!!!!!!!!!!!
    I use RGB mod and now collor is like Default screen settings on 4.1.3 WTF?
  18. manurd350
    manurd350 , Sep 26, 2017 :
    Yes I do that every time immediately after the update. Both app cache as well as from recovery. Battery do takes a hit every time but settles after few days, agreed. But this time it is different. My usual pattern gives me about 24 hours of battery with 3.5 to 4 hours of SOT, which is fine. However, after the update, 75% to 30% in just about 2-3 hours. This is strange. Also, what more strange is battery meter graph....see attached. Observing for a few discharge cycles.......
  19. viswajith645
    viswajith645 , Sep 26, 2017 :
    Thanks got the OTA Using VPN Master
  20. G_Andreas_Wittig_vDPd
    G_Andreas_Wittig_vDPd , Sep 26, 2017 :
    works very well for me. The icons are smaller than before - since I have an eyes issue I have large font and large symbols, but the icons are small anyway.
