637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. Bejoyk
    Gingerbread Sep 26, 2017
    Bejoyk , Sep 26, 2017 :
    its becoz one must be kb and other must be Kb(capital)...
  2. smitbhagat
    Honeycomb Sep 26, 2017
    smitbhagat , Sep 26, 2017 :
    cleared the cache and did a reboot,problem seems to be solved,i guess it was because of the Watermark feature
    G_Chinmay_bapat_oQMj likes this.
  3. prasar
    Froyo Sep 26, 2017
    prasar , Sep 26, 2017 :
    It's not on
  4. DracoPsycho
    Cupcake Sep 26, 2017
    DracoPsycho , Sep 26, 2017 :
    Hello, I can't seem to find information about this, so I ask. Does this update include September android security update or does it include oneplus specific patch for blueborne?
  5. ydvnitin
    ydvnitin , Sep 26, 2017 :
    Great work team oneplus, screen on time increased from 2.30-3 hours to 5 hours after the update with data always on.
    Sabbir.Naim likes this.
  6. rajismine
    Froyo Sep 26, 2017
    rajismine , Sep 26, 2017 :
    not complaining but something is odd with the update
    while i am loosing battery faster than before (did all cache cleaning ), now the battery stats are unavailable even at battery 89%. BTW i lost this 11% in 1 hour without using the phone much.
  7. Werner Weitzel
    Donut Sep 26, 2017
    Werner Weitzel , Sep 26, 2017 :
    Warte am besten bis du die komplette Rom als ZIP herunterladen kannst. Lade die auf deinen PC und schiebe sie in das Dateiverzeichnis deines Handys und dann sollte es funktionieren. Ist besser als nur das kleine Update. Viel Glück.
    Dresa91 likes this.
  8. G_vineeshmon_Plachery_Ek
    AdershThottungal likes this.
  9. AdershThottungal
    Froyo Sep 26, 2017
  10. Maxmxir
    Maxmxir , Sep 26, 2017 :
    Stop with battery life, wipe cache and wait 1 week for stability with the new Rom
  11. Dresa91
    User of the Year 2016 Sep 26, 2017
    Dresa91 , Sep 26, 2017 :
    No. You have to do a clean install. Wait till the FULL ZIP is available on dowload page
    Bobbie63 likes this.
  12. G_Arnav_Kalita_kpOp
    Froyo Sep 26, 2017
    G_Arnav_Kalita_kpOp , Sep 26, 2017 :
    Plz give the link to upgrade from 4.1.7 to 4.5 for Oneplus 3
  13. Maxmxir
    4.5.0 because this is stable
  14. Dresa91
    It depends on what you want
  15. G_vineeshmon_Plachery_Ek
  16. Dresa91
    Darekb81 and Bobbie63 like this.
  17. AdershThottungal
    Froyo Sep 26, 2017
  18. IamMrMayank
    IamMrMayank , Sep 26, 2017 :
    Hey! after updating my phone, I am unable to make phone calls via Reliance Jio SIM. what's the problem??
  19. Dresa91
    Download the FULL ZIP of 4.1.7, do a clean install and update to 4.5.0 via VPN
  20. AdershThottungal
    Froyo Sep 26, 2017
    AdershThottungal , Sep 26, 2017 :
    depends means, i wanna good battery backup dear n n also smooth interface
