637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. pradeep4031
    Eclair Sep 26, 2017
  2. Vivek@Mishra
    Cupcake Sep 26, 2017
  3. G_vineeshmon_Plachery_Ek
  4. Dresa91
    User of the Year 2016 Sep 26, 2017
    Dresa91 , Sep 26, 2017 :
    it always depends on your usage and how many apps are installed.
    Bobbie63 and AdershThottungal like this.
  5. AdershThottungal
    Froyo Sep 26, 2017
    AdershThottungal , Sep 26, 2017 :
    means wanna format my mob
  6. Dresa91
    Bobbie63 likes this.
  7. G_vineeshmon_Plachery_Ek
  8. G_Iurie_Dubencu_UPNx
    Sabbir.Naim likes this.
  9. Dresa91
    Yes. It is always recommended to do a clean install
  10. G_vineeshmon_Plachery_Ek
  11. Dresa91
    The same way you have installed beta....
  12. Dresa91
    Do a factory reset, don't import settings. Behave like you are setting up a new phone
  13. ryankwok
    ryankwok , Sep 26, 2017 :
    My 3T A3003
    • lift up display work 1 time only after reboot.
    • how to enable low priority notification?
  14. isht_kundu
    Donut Sep 26, 2017
    vik45 likes this.
  15. alejandrojdf
    Froyo Sep 26, 2017
    alejandrojdf , Sep 26, 2017 :
    Hi all,
    Since my last update (currently have Oxygen Os 4.1.7 and Android 7.1.1) I'm experiencing some issues, I have researched in forums and with most of them I'm not the only one who is facing these problems:
    1. Camera Focus: the camera doesn't focus anymore, I have to point it to direct sunlight or triying to move the camara really fast to obtain like 2 seconds window to take a picture with a decent focus.
    2. GPS with google maps and other third party apps now just does't work properly, the phone sometimes just simple cannot find the location or the navigation works really bad.
    3. My battery gets depleted faster than before.
    Have any of you experienced these issues? the new update have solve them??
    Thanks!
    Regards.
  16. AdershThottungal
    Froyo Sep 26, 2017
    Dresa91 likes this.
  17. G_vineeshmon_Plachery_Ek
  18. Dresa91
    I wonder how you was able to install Beta...
  19. O_DARSHAN_N_009
    Gingerbread Sep 26, 2017
  20. F_IDaniel_Delos_Santos_V
