637
OxygenOS 4.5.0 (7.1.1) OTA for the OnePlus 3 and 3T
  1. humanzqzr
    Honeycomb Sep 26, 2017
    humanzqzr , Sep 26, 2017 :
    It's reading mode not studying mode sanpandey. Oneplus 3/3T lack RGB so we will not get that feature. But you can use nougat quick settings apps to turn display in monochrome mode.
  2. VaibhavBhargava
    Lollipop Sep 26, 2017
    VaibhavBhargava , Sep 26, 2017 :
    Wrong quote bro
    humanzqzr likes this.
  3. humanzqzr
  4. vaston
    Eclair Sep 26, 2017
    vaston , Sep 26, 2017 :
    In current update the the sensitivity of the microphone in video and dictaphone is worse!
    Low volume record audio!!! Also change of display calibrate is worst than in previous version!!!
  5. kowshikpsg
    Froyo Sep 26, 2017
    kowshikpsg , Sep 26, 2017 :
    animation not same but the start up image is same like beta
  6. Kalpesh_Sisodiya
  7. humanzqzr
  8. uddikaushik8
    Cupcake Sep 26, 2017
  9. humanzqzr
    This shows your mentality of shitting. Read op first and then reply.
    VaibhavBhargava and Bobbie63 like this.
  10. SoniaB
    Nougat Head Moderator Sep 26, 2017
    SoniaB , Sep 26, 2017 :
    It is an incremental rollout as per the start post of the thread. Full rollout will just be starting
    Merged
    Sun90 and uddikaushik8 like this.
  11. Sinnaz0709
    Sinnaz0709 , Sep 26, 2017 :
    anyone knows if the GPS issue was resolved with this update ? Haven't got a chance to test this yet...
  12. G_Arun_S_HvfH
    G_Arun_S_HvfH , Sep 26, 2017 :
    It works now, thank you
  13. Dinesh_T
    Dinesh_T , Sep 26, 2017 :
    OK.. Just install EX file explorer app if you already don't have it.
    Then, in the app section click on camera app and you will get option to Uninstall the camera app then click on Uninstall. Then check the camera app in the phone it would start to work properly. I did only this much and it's working properly. Maybe we updated the camera app and after enabling watermark it's not working properly.
  14. Dinesh_T
    Cool [e]1f601[/e][e]1f44d[/e]
  15. Kalpesh_Sisodiya
    Kalpesh_Sisodiya , Sep 26, 2017 :
    This Shows u don't have any work other than shitting[e]1f602[/e]
  16. VaibhavBhargava
    This is definitely not your first OTA, then why do you keep asking such questions like what is the eta of ... update in india.
    It should be pretty obvious by now (even if you don't participate in this forum a lot), there is a thing called as global rollout.
    Rajesh Kumar C P likes this.
  17. VaibhavBhargava
    Sun90 likes this.
  18. btjayakody
    btjayakody , Sep 26, 2017 :
    See this is only options i get from gallery...
  19. F_Nurooddin_Kachwala_JuV
    Froyo Sep 26, 2017
  20. VaibhavBhargava
    btjayakody likes this.
