121
OxygenOS 4.5.1(7.1.1) OTA for the OnePlus 3 and 3T
  1. Cervantes
    Lollipop Moderator Oct 18, 2017
    Cervantes , Oct 18, 2017 :
    Thread merged
    This thread is a question and answer
    Sun90 likes this.
  2. cmitchellshaw
    KitKat Oct 18, 2017
    cmitchellshaw , Oct 18, 2017 :
    And so you started a whole new thread?
    Just so you'll know, it's considered bad form (and a violation of the rules) to start a new thread without searching for similar threads first. Please use the search feature next time.
    VaibhavBhargava and chucho like this.
  3. Sehej Jain
    Ice Cream Sandwich Oct 18, 2017
  4. Cervantes
    Thread merged
    this thread is a question and answer
    Sun90 likes this.
  5. klediouron
    Froyo Oct 18, 2017
    klediouron , Oct 18, 2017 :
    Oh what happened to the font size ? It was so smooth with 4.5.0 by default, and it is so big with 4.5.1.
    EDIT : display size was now at "big" by default, if you were using default don't be surprised, you just have to change display size "by default"
  6. Vedang upadhye
    Gingerbread Oct 18, 2017
    Vedang upadhye , Oct 18, 2017 :
    I hope this update fixes my storage problem
    with apps just constituting approximately 5gb and other thing around 30gb
  7. DieterP
    Donut Oct 18, 2017
    DieterP , Oct 18, 2017 :
    The bluetooth media streaming issue is still present in 4.5.1. Broken since 4.1.7, unbelievable..
    ihonize, UltrAs81 and Mkmanis11 like this.
  8. G_Tech_Talk_and_Gadgets_
    Cupcake Oct 18, 2017
  9. G_Ali_Waheed_ZxbS
  10. Amsso.
  11. Vidnomenon
    kpoyser likes this.
  12. tranced_
    Donut Oct 18, 2017
    tranced_ , Oct 18, 2017 :
    UPDATE: Never mind. I compared to a friend's 3T(4.5.0) and it's the same.
    Hey all! Newbie here with an OP device.
    But I'm likely sure that the "Storage & memory" section has changed. Now it shows "XX.YY GB used of 53.63 GB". I believe that previously showed the space left. Can anyone confirm?
  13. YEATESH
    Donut Oct 18, 2017
  14. radarshnair
    Donut Oct 18, 2017
    radarshnair , Oct 18, 2017 :
    Hi all,
    Have received this minor update with the update log as general bug fixes and stability improvements. Has anyone else received this update?
  15. Thibault_Sents
  16. Thibault_Sents
  17. G_karmvir_singh_qjEb
  18. G_TV95_MeLm
    G_TV95_MeLm , Oct 18, 2017 :
    Slight issue.
    I went to my System Updates page and tapped on "Check for Updates". It showed me update available 4.5.1......34MB download. I tapped download. After the download completed, I tapped on the Reboot to Upgrade option but nothing happened. Then I waited 10 seconds and tapped again. Now it showed me "Continue Download" I tapped again and it got stuck on 5%. I exited the page and then came back to it again and it showed me "Reboot to Upgrade" and I tapped again but the same thing happened. Anyways I rebooted manually, it took me to the update screen and it showed "Update Failed" I restarted the device.
    Now it's telling me to download the 1498MB file.
    Will that remove my apps and settings and data? If so, how can I get the normal 34MB download again?
  19. Venkatraman Pillai
  20. deathmiro
