303
OxygenOS 4.5.10 OTA for the OnePlus 5
  1. MahilKr
    Donut Sep 7, 2017
  2. otto2
    Photography Expert Sep 7, 2017
    otto2 , Sep 7, 2017 :
    Battery drain? Really? Must be one of your Apps... Proof attached. Screenshot_20170906-175117.png
    MikeG247 likes this.
  3. zoarquenix
    Froyo Sep 8, 2017
    zoarquenix , Sep 8, 2017 :
    Yeah, me too.
    Majority of the comments are : whines, then command. Without providing any useful information, while not considering how they use and set their phone that causes those problems...
    Have you tried clearing cache on recovery?
    otto2 likes this.
  4. G_Denis_Agioski_qKys
    Cupcake Sep 8, 2017
    G_Denis_Agioski_qKys , Sep 8, 2017 :
    i have a problem one time. When i buy new OnePlus 5 and i start the update and the software of my phone is going down (it's fall) and now i use OxygenOS 4.5.0. so it's secured if i make again that update or i need to wait??
  5. G_Denis_Agioski_qKys
    Cupcake Sep 8, 2017
  6. vriesdejoop
    Ice Cream Sandwich Sep 8, 2017
    vriesdejoop , Sep 8, 2017 :
    Fix:
    • Open filemanager
    • Make sure you see hidden files, use the 3 dots right top, settings, activate show hidden files
    • click on internal
    • find .Ota (dotOta) directory and delete this
    • look again for the update in settings and update!
  7. Himanshu0000608
  8. Adelinelehardy
    Cupcake Sep 8, 2017
    Adelinelehardy , Sep 8, 2017 :
    Hello, I have some issues with Google Maps since the upgrade, the GPS signal is often lost or takes time to stick. Any idea of solution for this? Thanks a lot!
  9. Anvesh Racharla
    Cupcake Sep 8, 2017
    Anvesh Racharla , Sep 8, 2017 :
    after this update battery getting drain too fast nd phone getting heat while charging frm this update ....plz solve this ASAP
  10. Badsha_Khan
    Cupcake Sep 8, 2017
  11. hoezaay
    Eclair Sep 8, 2017
    hoezaay , Sep 8, 2017 :
    I can confirm this to be true ...I tried everything after using the search function extensively .. wiping cache ..factory reset . .. everything... severe battery drain on 4.5.10 .. I went back to 4.5.8 and the drain is gone.
  12. marcusskyfall
    Jelly Bean Sep 8, 2017
    marcusskyfall , Sep 8, 2017 :
    Are you using a case? If you are make sure the cable is properly seated
  13. Aravimd
    Eclair Sep 8, 2017
    Aravimd , Sep 8, 2017 :
    I din get any much drain with 4.5.10... but anyways how to revert to 4.5.8?
  14. ForumDuChef
    Eclair Sep 8, 2017
    ForumDuChef , Sep 8, 2017 :
    Waaaaooow What a clever question !!!
    otto2 likes this.
  15. hoezaay
    Eclair Sep 8, 2017
    download the firmware from the one plus site .. place the zip file in your phone (root folder) .. ... flash it from system update --> local upgrade .. or boot into recovery and flash from there .. don't forget to wipe for a clean install
  16. F_Sravan_Vanam_nFAU
    Cupcake Sep 8, 2017
  17. F_Sravan_Vanam_nFAU
    Cupcake Sep 8, 2017
    F_Sravan_Vanam_nFAU , Sep 8, 2017 :
    what's the use of opera vpn.
  18. shubhambhagwatyadav
    Froyo Sep 8, 2017
    shubhambhagwatyadav , Sep 8, 2017 :
    To encrypt data from your ISP, to spoof your location and to unblock some restricted websites.
  19. Jarrahtv
    Eclair Sep 8, 2017
    Jarrahtv , Sep 8, 2017 :
    i get the same problem on Pixel XL, so I think it's normal
  20. zoarquenix
    Froyo Sep 8, 2017
    Perhaps they should hire you to improve it?
    MikeG247 and otto2 like this.
